Thanks Budgie  you are very welcome  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
hi Mike. you mentioned mahogany planking, is it same thickness as normal planking. wondering how it will bend being hard wood, and if it will pin without being drilled first. and if you will be painting it or danish oil to bring out its natural colour. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian sorry I missed your post The mag planking is 5mm x 2mm and yes it is not easy to bend consistantly. I soaked the planks in hot water for at least 20 mins then fitted the planks to the hull wet with out adhesive using pins is not a problem, you need to drill the planks when you have tapered the planks so the pins do not split the wood.when the planks are dry I remove them, bevel the edges and taper where required, then fit again using adhesive. I will use Danish oil when the Hull is sanded Thanks for your question Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
Mike there is something you can add to water to help soften the wood fibres to help them bend, i will look it up and let you know Come on you Jimmies
Aparantly if you add Ammonia to the water it helps soften the planks more, it is supposed to be good for hardwoods such as Walnut. Now I suppose this might bring in some comments, as we all have a reliable source of ammonia, so I'm not suggesting we all pee on our wood  This info comes from Planking techniques for model builders, Underhill lent me a copy a few months ago one of his old relations gets qite a few mentions in it as he was a plan designer and model builder. Come on you Jimmies
Thanks Bob for the info on this formula  I will give it a try  but with real ammonia  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
HULL WITH BALSA FILLETS Hi Team the Balsa has now been sanded,faired and formed  all I have to do now is a little more medium sanding,the shape at the stern is great fof fitting the planks,see what you think:- Questions and comments welcome  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
hi mike. Very tidy filliting, looking forward to seeing your mahogany palanking Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 13/02/2011 Posts: 2,243 Points: 6,849 Location: East Sussex
Hi Mike, love the balsa,good job. Regards trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks Trev for your comments  I have just finished all the fairing, I will post the Photos soon  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
BALSA FILLETS ON THE HULL Hi Team as you know I have been fitting the whole Cutty Sark Hull with balsa wood here is the finished job:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 good stuff Mike bet she weighs a lot more now  me thinks you will be glad to start planking now
BALSA FILLETS ON THE HULL The last two photos show how easy it has been to get the shape of the Stern using this balsa method. I am really pleased with the outcome, I have a great base to start my planking  Questions and comments welcome. Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Budgie you are spot on, on both counts  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
That's looking good Mike. I might have to try the balsa method on my next model.
Thank you allan for your nice comment  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Looking good Mike Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you Andy  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looking good mike. look forward to seeing soome more pictures ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
She is looking great Mike!!..  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
