19 Pages «<1011121314>»
Tom Options
Son of Bulwark
#221 Posted : 05 February 2012 19:11:18
Hi Tom! Cool
I would agree with John those last two pictures really show the work needed to shape the tiles around the bow and stern. A job well done! Yes a little more work to finish, but what a grand looking ship, it’s no surprise you’re in love with her mate!.
Love
Darron
Atholm
#222 Posted : 06 February 2012 07:26:39
Hi Tom
Love the neat work must have taken many hours and more patience than I have.
Well done
Athol
Foz
#223 Posted : 06 February 2012 10:05:21
A really beautifuul build there Tom. Keep up the great work.
Foz
#224 Posted : 06 February 2012 10:35:41
Absolutely beautiful build, Tom. Just proves what time and effort can do. Will be following your build closely
riff-raff
#225 Posted : 06 February 2012 13:47:25
Impressive mate - very impressive
Built:
farrabass
#226 Posted : 06 February 2012 16:18:10
Fantastic job with the tiling Tom!
Very professional job, just a few more cuts to fit in and "Job done"
All the best Steve..
DaDokta
#227 Posted : 07 February 2012 11:42:44
Very impressive!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
tom.ganc
#228 Posted : 02 March 2012 14:37:21
Hello again
I was having little brake from copper recently and I thought I'll get the roundhouses ready. I knew that fitting arches on roundhouses will be tricky, and I wasn't wrong. After few tries of bending supplied wooden arches I decided that it must be easier way of doing it.
I used the "green stuff" and one of the supplied metal arches to get mold.
1. I prepared some green stuff to push metal arches into it. I covered the arches with some oil so I could recover it later. Othervise green stuff will just stick to them and end of story.
2. I left it like this for few hours so green stuff became harder. After that i mixed another portion and filled earlier prepared mold (don't forget about applying some oil on the mold)
3. I left it again for few hours and pulled our from the mold. Then I used craft knife to get rid of excess of material. You should get something like this.
Green stuff is flexible at this stage so when I tried to wrap it around roundhouse it just fits perfectly.
I'm going to paint them now and when they ready just use superglue to put stick them on.
I'll post more pics when I finish.
I hope this will make your life just little easier. :)
saintsman123
#229 Posted : 02 March 2012 15:07:02
great idea tomBigGrin
Come on you Jimmies
farrabass
#230 Posted : 19 May 2012 12:55:58
Not had an update from you for a while!
Good idea with the green stuff by the wayBigGrin
#231 Posted : 19 May 2012 16:24:55
BigGrin Great idea gives me scope on an idea i haveCool
#232 Posted : 20 May 2012 21:33:11
Good plan. may I ask what oil you have used? how have you found painting the oiled part or how do you clean the part.
thanks
tom.ganc
#233 Posted : 24 May 2012 15:50:28
Ho Jase,
I used normal cooking oil. After I finished moulding I washed it up properly to get rid of all oil. Didn't have muvh problems painting it. You can use primer prior to painting to improove it slightly.
Cheers
Tom
#234 Posted : 24 May 2012 21:12:26
Brill idea!! I will contact my local model shop to see if they stock green stuff...thanks for the tip Tom!!
Wink ThumpUp
#235 Posted : 25 May 2012 14:30:51
Hi Tom, some brilliant ideas there. Being in the good ol'e RSA would you be able to specify what the "green stuff" is for greenhorns like myself. Thanks
Mr.Quist
#236 Posted : 28 May 2012 13:08:39
Hi Tom,
I keep admiring your build very much.
Now that your have finished your copper tile, I have one question:
What type of glue did you use for that?
I am stuck at issue 50 and coppering is still ahead.
Regards, Timm
My build diary here
HMS Victory
Dontshootme
#237 Posted : 28 May 2012 16:22:25
Green Stuff is a two-part modelling putty that is useful for filling in gaps on models and sculpting additional details. When the two colours(Blue & Yellow..hence "Green Stuff" are mixed together, they form a malleable putty that can be applied to plastic, resin and metal miniatures and then moulded into shape using a Sculpting Tool. Once it has fully cured, Green Stuff is solid enough to glue other components to and can be painted over.
Heres a SA link I found http://www.wantitall.co....lling-Putty__B000FCLTY4 hope that helps you out.If not try ebay or look for a WarHammer stockist.
#238 Posted : 29 May 2012 10:04:02
Thank you very much Rob. I have checked out the site and will follow up thanks once again for the info
StefanDV
#239 Posted : 29 May 2012 10:37:11
That's VERY expensive! I'm going to look for an alternative before ordering from them.
tom.ganc
#240 Posted : 28 October 2021 11:42:57
BigGrin BigGrin BigGrin Hello everyone after such a long break.
I had to pause my build due to couple house moves over last years. I managed to save everything securely and my Victory is waiting patiently for reunite. I'm sorting my loft area where I'm going to have my cave and where I can start on her again. I'm dying to get my hands on her again and to catch up with everything I did so far.
I will need to find a way to clean my copper planking somehow as there are some of them missing and I hope to get them all replaced and finished off.
It will take me some time to catch up with what I've done and what still needs doing.
I look forward to hearing from you guys.
Best regards
Tom
This page was generated in 0.830 seconds.
