20 Pages «<1112131415>»
Karl's H.M.V Endevour.Part work's with Eaglemoss. Options
#241 Posted : 19 April 2012 13:33:20
week 65. windows,scroll across the top and a couple of moulding pieces to fit this week,not much to say really,'cept I had to file down the window frames to get them in.
#242 Posted : 19 April 2012 14:55:21
Nice detail..
alantait
#243 Posted : 19 April 2012 15:35:22
Hi Karl, although it looks nice, i am not sure about the "painted windows" i have the feeling that i will cut these out and use a Acetate sheet as in the victory. apart from that she is looking a neat ship, keep up the good work.
current builds
#244 Posted : 19 April 2012 17:51:16
hi alan,good luck with the windows,I didn't think that the design would incorporate see through windows too well,as the side windows are also solid lumps of white metal which I presume will the same light blue.Mellow
alantait
#245 Posted : 19 April 2012 18:06:15
Hi Karl, Yes seen the side windows which i have drilled out and filed to shape, i know there is nothing inside such as decks etc. but since i have not yet started the build i will add some deck area. i suppose i am lucky i did not start from the beginning and have stored all the parts so i know most of the pitfalls thanks to yourself and others.
i would expect that you may well have done something similar in hind sight, knowing your fantastic attention to detail.
all the best
current builds
IAN
#246 Posted : 19 April 2012 20:10:48
Hi Karl..
the Endeavour is looking great.,
Best regards,
Ian
Ian
Wish list: Bentley Blower
Silent_Running
#247 Posted : 20 April 2012 12:28:16
Great work Karl! Well done! ThumpUp
#248 Posted : 20 April 2012 13:02:48
that you very much for the comments.they are appreciated Cool
#249 Posted : 10 May 2012 13:43:45
week 68,and a mammoth amount of work,a WHOLE rudder to do.
alantait
#250 Posted : 10 May 2012 17:00:58
Hi Karl, your sarcasms getting better with age, i agree i picked my copy up about 10 minutes ago and couldnt believe what we are doing this week... it will take the whole week to complete this especially if i make cups of tea every half hour or so Flapper . might just plank the rudder to make it last longerLOL
current builds
#251 Posted : 10 May 2012 17:44:25
SARCASM,SARCASM,sarcasm,nawwwwwwwww,for the endeavour that is a lot of work.
The bearded 1
#252 Posted : 11 May 2012 03:06:46
Hi Karl. The Endevour is looking great. I noticed the rudder seems to be made static, don't like this, am going to try to make it a working rudder. Turn the ships wheel, rudder turns (wish me luck on that one) Want more pics and tips.BigGrin
Current builds:
The Victory (of course)
The Endeavour
The Bismarck
Lancaster Bomber
And any model kit that catches my eye
Everything from 1/35 military to Godzilla and anything in between.
Oh and a suit of armour. ( yes real knights armour )
#253 Posted : 11 May 2012 14:53:42
hi bearded 1.I intend to do the same,by using pullys and blocks as the original.also will be adding some other mods,
#254 Posted : 18 May 2012 16:04:49
week 69. the rudder installation this week,started by drilling and filing to let the rudder inthe ship,I found this reasonably easy.
#255 Posted : 18 May 2012 16:05:56
#256 Posted : 18 May 2012 16:07:21
the next part was to drill the top of the rudder for the tiller.
#257 Posted : 18 May 2012 16:12:05
didn't care for the wood supplied or the method of fitting the tiller,reducing the tiller down to 2mm.x2mm. far to weak,so I made another from wallnut 4mm. x4mm.and the used a cocktail stick for the end of the shaft.much better.
#258 Posted : 18 May 2012 16:14:08
http://s909.photobucket....mp;current=IMG_8589.jpg
http://s909.photobucket....mp;current=IMG_8588.jpg
and lastly, fitted the rudder hinges.
#259 Posted : 18 May 2012 16:15:12
#260 Posted : 24 May 2012 16:19:28
week70,and another bumper week this is!78 pieces involved,though you only ONLY
have to fit 6 of them,they are called the breakwater sheets.the bits that hold the spritsail mast.two pieces laminated by three pieces each.ermmmmm can't think of anything else to say.
