Wood For Assembly Jig? Options
extinctionjet
#1 Posted : 01 October 2012 04:50:15
Hi, I have just started the Sov, and im looking to buy some appropriate wood to construct it with, im just having a hard time finding it, can you advise me where to buy such wood for base board and plywood It appears hard finding the wood, i could not find any such related posts either... thanks.
sam
#2 Posted : 01 October 2012 06:39:35
BigGrin Hi Jet
try your local B and Q or simular or a cheeper way is to visit your local wood yard or joiners yard for off cuts.Hope this helps
Aldo
#3 Posted : 01 October 2012 08:53:38
From the previous replies it needs to be at least 8" wide and 30" long and 10mm thick. If Im wrong Im sure someone will put you right. BigGrin
#4 Posted : 01 October 2012 11:56:56
hi aldo,15mm. thick is best,b & q. I found best,it had all the materials required,and they will cut the wood if necessary.12"(30cm.) the best all round size is 1mtr. x 30mm.wide and 15-20mm thick.with 6" (10.5cm.)brackets.
court orchard
#5 Posted : 01 October 2012 12:10:17
Sorry Karl, don't you mean a width of 30cm not mm.
Sillvestra
#6 Posted : 01 October 2012 14:12:47
I picked up a pine shelf from wickes for approx £8 which was ideal size for the jig base. For brackets, I am using corner reinforcements which are approx £4 for 4 at b&q. Plywood came from b&q also. The only problem there is that they do 6mm thickness and not 5mm... Having the large sheet cut into 3 smaller ones was definitely a plus BigGrin
I''ll be starting a build diary soon as I now have a clear work space and will include pictures of my jig at the start of it BigGrin
Current Builds:
- HMS Sovereign of the Seas
Planning on Building:
- Scratch built HMS Victory full detail interior (I know what's inside even if you can't see it BigGrin)
Completed Builds:
#7 Posted : 01 October 2012 21:25:27
I have also struggled to get suitable wood. Don't drive and live in Swindon so a double problem.
Resorted to the Internet and got my ply from w hobby ltd
http://hobby.uk.com/cata...d+panel&x=0&y=0
Part number P12 was the ply I ordered as its 4mm thick. Panels are really flat and clean so happy with my purchase.
My shelf (ordered 2) were delivered from wickes at no more cost than a return taxi ride.
http://m.wickes.co.uk/mt.../165068?un_jtt_redirect
Hope this might help
Kind regards
Tony
W Hobby catalogue available in WH Smiths and has some very good items in it
Aldo
#8 Posted : 02 October 2012 09:18:49
So 100cm X 30cm and 15mm thick is this correct ? If so I'll try and get a new piece today.
court orchard
#9 Posted : 02 October 2012 10:24:46
That should be fine, the important thing is that it is totally flat.
extinctionjet
#10 Posted : 06 October 2012 04:49:13
Awesome! but for the brackets, doesnt it say 3 slightly larger than 3?
So what brackets would do?!
Hector
#11 Posted : 09 October 2012 11:08:06
For my 5mm ply i went to the local scrap yard and got lots for free from a van interior lining,also found some on a bonfire pile in a bed base but the rain got there first,salvaged my brackets from same pile reclaimed from a wardrobe.
Theres lots of useful bits around for free,wifes nail files are great for getting in the tight spots along with her tweezers,all my files are kept in a cleaned bean can,take-away food containers/coffee jars etc for storage
Tell me the truth,I shall not offend nor be offended
Trotsky
#12 Posted : 09 October 2012 14:44:49
Recycling stuff is a great idea... when you start looking around for stuff to use the list is endless ....well done Hector any other suggestions folks?
H.M.S Victory
H.M.S Victory X Section
D-51
court orchard
#13 Posted : 09 October 2012 15:30:47
Wife's tweezers and nail files free? There will be a cost to that when she finds outLOL
I'm finding the little plastic cannon packets perfect for dispensing small amounts of glue & paint.
It's amazing what some people throw away, if you keep your eyes open.
Sillvestra
#14 Posted : 09 October 2012 16:36:31
I'm a car mechanic by trade. My tool box at work has been raided of duplicate tools to fuel my growing SotS build tool collection BigGrin
Current Builds:
Completed Builds:
Hector
#15 Posted : 12 October 2012 11:21:34
She was fine with the tweezers and files,it was the built-in vanity table i made her and completed just in time to use as my build space that really upset herLOLLOL
Question:said space is built-in to the alcove aside the chimney breast so is walled in on 3 sides,measures 1240mm x 380mm so its gonna be snug and i cant work 360deg around the model,is this going to be workable as i progress?
court orchard
#16 Posted : 12 October 2012 12:20:14
Hi, You are going to need to turn the model frequently when planking or rigging for example. I use a rotating platter, it came with a cheese set from a cheap cook shop. This is because you need to do some of the building in a balanced way to avoid too much force all on one side.
catman275
#17 Posted : 12 October 2012 12:39:47
Tools?,
I have a bag of heavy rubber bands courtesy of the postmen who generally drop them during their rounds.
Peter
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
