56 Pages «<4445464748>»
MWG build diary of the mighty Hood Options
#901 Posted : 03 October 2012 21:45:07
Ger C wrote:
Can't wait to see the finished model
Thank you GerBigGrin Regards Mike
#902 Posted : 03 October 2012 21:46:47
BigGrin Nice work as ussual MikeCool
Hi Andy I appreciate the commentBigGrin Regards Mike
#903 Posted : 04 October 2012 13:52:11
Good looking build there Mike. Looks real with weathering. Great job.
#904 Posted : 04 October 2012 19:13:01
Hi Hans, thanks again for your kind commentsBigGrin Regards Mike
Virtue86
#905 Posted : 05 October 2012 14:02:29
Mike
The turrets look great, its going to be a cracking model when you get to the end of issue 150. Keep up the great work
Pete
Cheers
Peter
Current builds: Amati 1:200 Hood; D51 200
Bought and on the waiting list: HMS Endeavour's Longboat, 1:90 San Juan Nepomuceno, Titanic Lifeboat,1:200 Bismarck Strip and Rebuild
[b]Built:1:250 Titanic
#906 Posted : 05 October 2012 18:36:18
Virtue86 wrote:
Mike
Pete
Hi Pete, thank you for your nice commentsBigGrin Regards Mike
#907 Posted : 17 October 2012 12:32:12
ISSUE 57 BUILD
Hi team this is a seriously time consuming buildBlink you do need some good specticles to see your way round this oneHuh
The object of the exercise is to build the first of the models Pom Pom Guns
This is what we recrived:-
Good luck
#908 Posted : 17 October 2012 12:37:56
ISSUE 57 BUILD
There are approx 30 brass etch parts on a fret approx 2 x 2 inches,and so it is time consuming.
I followed the instructions and here is the build, I did make sure all burrs were filed off the parts:-
#909 Posted : 17 October 2012 12:43:01
ISSUE 57 BUILD
Thats all for this session, not alot to show for a few hours workBigGrin Questions and comments always welcome.
I will leave you with a photo of where we are with this issues build finished:-
Kind regards Mike
#910 Posted : 17 October 2012 13:18:22
Hi Mike.
Great job on pom pom gun. i bet the boxes on the side were fidley to glue together. look forward to seeing them aged ianCool
#911 Posted : 17 October 2012 13:25:04
ian smith wrote:
Hi Mike.
Hi Ian, you are not wrong each magazine has 5 parts and it measures approx 8 x 5 mm. I will look forward to weathering it
Regards Mike
moriarty
#912 Posted : 17 October 2012 13:33:43
Yeh c,mon Mike ,that is gonna look the real deal with a paint jobLove Laugh Cool BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#913 Posted : 17 October 2012 14:38:22
Hi Moriarty, you are rightLove Regards Mike
Virtue86
#914 Posted : 18 October 2012 16:55:46
Mike
Just as well my eye's work better over a short distance than they do over long distances, this bit looks quite fun. Well done with it, im still second planking the hull in the spare 5 minutes i get now and then.
With regard to the sanding sealer you have mentioned in previous posts, i haven't used it before and am unsure of how to apply it. Do you just paint it on in thin layers and sand back?
Your build is looking particularly good
Cheers
Peter
Cheers
Peter
Gus W
#915 Posted : 18 October 2012 19:23:39
Coming on very nicely Mike.
Cheers
Gus
Currently Building:
Eaglemoss HMB Endeavour
De Agostini Sovereign of the Seas
#916 Posted : 18 October 2012 22:08:37
Virtue86 wrote:
Mike
Cheers
Peter
Hi Peter, thank you, just paint it on but please make sure your Hull is as smooth as a babies bum, and use it in a well ventilated room, it should ideally be used after you are totally happy with the Hull finish, it will then seal your work the grain will rise, just light sand it again
#917 Posted : 18 October 2012 22:09:43
Cheers
Gus
Hi Gus thank youBigGrin Regards Mike
willie
#918 Posted : 19 October 2012 13:23:28
MWG wrote:
ISSUE 57 BUILD
Good luck
just a quire did you recive the two fretts for the pompom guns in that issue as i recived one and an other frett looks like the sights for the small antie air craft gunsConfused
#919 Posted : 19 October 2012 15:27:01
willie wrote:
MWG wrote:
ISSUE 57 BUILD
Good luck
Hi Willie I didBigGrin Regards Mike
#920 Posted : 19 October 2012 21:29:23
BigGrin Hi Mike nice work on the pom poms,some extra detail on the Yam ato like this would have been nice
