40 Pages «<910111213>»
MWG build diary of HMS Sovereign of the Seas Options
Riggers
#201 Posted : 16 October 2012 22:39:55
Hi Mike, although I'm building the Victory I've found your SOTS build dairy very interesting the tips and techniques are coming in very handy on my own build so thanks for that. Keep the pictures coming mate BigGrin
Cheers
Chris
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
#202 Posted : 17 October 2012 01:16:13
Cheers
Chris
Hi Chris, glad I am able to help youBigGrin Kind regards Mike
#203 Posted : 17 October 2012 13:26:53
Hi Mike.
Realy nice tidy bow fillets, look forward to seeing more of the ship wrights work. IanCool
#204 Posted : 17 October 2012 13:28:19
ISSUE 7 BUILD
Well team it is time to build the last section of the Keel.
This what we received this week:-
#205 Posted : 17 October 2012 13:33:22
ISSUE 7 BUILD
I assembled rib 22 after removing loose ash, again while using adhesive I placed it on my board with plastic on it:-
#206 Posted : 17 October 2012 13:39:13
ISSUE 7 BUILD
Then I put all the other parts in my Tile press (I have 10 tiles on top now because of the amount of product inside )
Now I am going on to my DRY DOCK and laying out the Keel with the angle brackets, first check all the brackets are square:-
#207 Posted : 17 October 2012 13:42:54
DRY DOCK BUILD 1
First I draw a line down the centre of the board, and place the Keel flat on the board so that you can see where the brackets will fit and also it will show how many you need:-
#208 Posted : 17 October 2012 13:49:44
THE DRY DOCK BUILD 2
I used 6 angle brackets per side.
once I had used the keels edge to position my brackets I fixed them to the board. Once that was completed I started to assemble the Keel and fix with adhesive, using spare frames for spacers:-
#209 Posted : 17 October 2012 13:52:46
THE DRY DOCK BUILD 3
I now fitted the support to the other side and clamped them using heavy clamps:-
#210 Posted : 17 October 2012 14:00:31
THE DRY DOCK BUILD 4
As I built the Keel I fitted the brackets on the other side of the Keel, therefore maintaining a straight Keel (please note we do not use any fancy tools, keep it simple this hobby is expensive enough)
I continued to join the Keel with adhesive and spacers as I went along, at the same time fitting the brackets on the other side.
I substituted the 2 red clamps for my trusty long bar clamps making sure the joint was well compressed and straight:-
#211 Posted : 17 October 2012 14:09:42
THE DRY DOCK BUILD 5
I have used the stand for the Bow as supplied in the Kit but I have not fixed it to the board,preffering to let it rest free and not under any strain, and really just giving me the angle for the bow plus some support when I fit the forward ribsBigGrin Thats all for this session, I will let the adhesive harden and fit the ribs tomorrow
Questions and comments welcome Kind regards Mike
The last Photo shows the stand in situ, please note the ribs in the photo are put in for spacers (I had a couple spare)
#212 Posted : 17 October 2012 14:40:44
THE DRY DOCK BUILD
Sorry I missed this Photo Regards Mike
cptcrash
#213 Posted : 17 October 2012 16:09:37
Doh why didn't I think of the spacer idea would have made things a whole lot easier :/ cheers for the tip mike
Admiral Anti Spiral
#214 Posted : 17 October 2012 17:24:47
Hey MWG, i noticed you updated on wednesday which made me wonder if the magazines come in, so went in today and picked up issue 7 :D, so in a wa thanks, the build is looking great looking forward to more of your build :)
Processing - Progressing
Previous builds: HMS Victory
#215 Posted : 17 October 2012 20:07:05
Your usual high standard being displayed Mike.. very informative as always.... keep posting the pics, they are an excellent teaching tool for many of us...
#216 Posted : 18 October 2012 08:51:38
The Balsa tutorial is coming soonBigGrin but next is the ribs. Regards Mike
#217 Posted : 18 October 2012 08:52:57
Yes every wednesday I pick up my issue at 06.30 hrsBigGrin Regards Mike
#218 Posted : 18 October 2012 08:53:59
Hi Alan thank you for the commentsBigGrin Regards Mike
#219 Posted : 19 October 2012 19:16:07
ISSUE 7 BUILD
Hi Team here we go with the most important stage of the build, get this wrong and your ship/ keel will end up in the shape of a snake.
STAGE 1
In this stage we have built the DRY DOCK and laid the Keel, I am very pleased with my ship now the adhesive is totally cured.
STAGE 2
This is where we fit 90% of the ribs, making sure they are all running true, you can not rush this stage, so please take your time.
STAGE 3
This is where I will fit the Balsa infills, for those members who are following my build and wish to use the Balsa methode please note this is my preffered way of completing this stage, other builders will have their own way of doing things.
So on to stage 2
I have included lots of photos.
First up we fit the Bow rib, I have already filled this part with balsa and faired it off the ship (it is easier)
#220 Posted : 19 October 2012 19:31:26
ISSUE 7 BUILD
I have not laboured on how to fit each rib, but I sanded the slots removing all the loose ash with an emery board (ladies use them for their nails) I made sure the ribs were totally home by taping them in with a small hammer and a piece of wood (see photo)Plus I used a set square to make sure the ribs were at 90 degrees to the Hull.
When the ribs had cured I turned the ship over and sanded where the ribs meet the Keel:-
Guest (6)
This page was generated in 0.629 seconds.
