Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
I have been looking ahead at some things, I see there are columns to be fitted between the mullions of the windows of the Captains Quarters, I have tried mine, and the gap is to small to take the metal columns supplied. Has anyone else got this far, or could you check your bits to see if they fit.
Mo Mo
 Hi it may be a case of file to fit,but obviously takeing an equal amount from each end ,just guessing here as i havent seen there size/shape perhaps a look at magpie,s build to see what he did is a must i think Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Mine all fitted Mo with not too much trouble, just a bit off filing on the side ones too get the angle. HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
ok Thanks for that, a bit of fileing will be done.
MoMo
