Uneven framesm Options
syd4444
#1 Posted : 04 November 2012 21:31:24
Rank: Amateur Level 1
This is my first build. I have my false keel sitting in a jig made off right angle brackets. My problem is with the frames. If I put a straight edge over the frames from 5 to 21 all of the ones between them are about 1/32 " lower. I would like to ask one of the experts is, are the lower frames correct or, are the higher frames correct. What is the reference point that I should be working to.
Ger C
#2 Posted : 04 November 2012 22:38:33
Hi,
Sorry that I can't offer better advice but if you look at some of thie other builds I think she rises towards the stern,
Hope this helps q
#3 Posted : 04 November 2012 23:43:43
hi,yes the frames 21 upwards do rise toward the stern(back end)the rest should be level, including the bow(front,)
syd4444
#4 Posted : 05 November 2012 10:44:53
Thanks for the info, but i'm a bit confused. Do I raise the frames in between 5 to 21 up to them or do I lower 5 and 21.
#5 Posted : 05 November 2012 11:27:16
Hi Syd, Just make sure all the frames up to frame 21 are fitted to the bottem of the keel (including rib 22 when it comes) and the top level of the ribs will be correct. As Mr T says rib 26 (when it comes,) will not sit at the bottem of the Keel it will be approx 20mm higherBigGrin Regards Mike
syd4444
#6 Posted : 05 November 2012 12:55:15
Many Thanks
