162 Pages «<678910>»
#141 Posted : 09 November 2012 20:29:03
karl1113 wrote:
I personally keep powertools well away from the delicate work,I'm much to clumsy,I use sandpaper on a piece of planking,several grades,and fair very gently,takes about an hour or so.also have dowel stick with stuck on sandpaper for the curved bits.
Thanks Karl, finding lots of tips and ideas here, just couldn't believe how fragile the launch ribs really were... delicate work requiring lots of patience and a gentle hand... so far so good though... Agree with powertools though, need to do some practice work first I think.....Cool
#142 Posted : 09 November 2012 20:30:50
claret wrote:
Hi Alan,
Looks excellent, the balsa work and fairing is bril!
Claret
Appreciate the nice comments Claret... lot of work but would recommend it for easier planking and of course making the hull more sturdy..... am following your diary and do like what I see...
court orchard
#143 Posted : 09 November 2012 20:46:38
I've found the Dremel invaluable for sanding work on fine detail. It's true that it's dangerous if you don't take enough care. But if I've done far more damage over the years with hand tools. For example, cleats on yards, I struggled to taper these off yard with the wood more often than not spliting. It was so much easier to taper them in situ with the Dremel.
#144 Posted : 09 November 2012 20:49:13
Interesting Andy, I will give it some practice and let you know how I get on..... should be fun if nothing else....
court orchard
#145 Posted : 09 November 2012 21:02:32
Fortes fortuna juvatLaugh
#146 Posted : 09 November 2012 21:22:32
don't misunderstand me,I use powertools a lot.but those meant for the job,i.e. proxxon fret saw,saw table,lathe,plus the unimat-1 multi tool.which has a millimg machine,lathe,sander,drill,jig saw,all have there place,if you can use a sledgehammer to put in a brass tack you are skilful indeed,and admire you for it,but I tend to be a bit heavy handed in my old age and have to be careful.btw,if you go to index you will find powertools there.
court orchard
#147 Posted : 09 November 2012 21:34:12
Didn't mean to crticise Karl, I have found miniature power tools better in certain situations, horses for courses, just trying to offer options which may not suit everyone.
#148 Posted : 09 November 2012 21:40:46
No misunderstanding here Karl, appreciate all the tips and advice I can get as a novice. I too use powertools, just never tried them on delicate pieces so intend to have a practice with the dremel. Sort of hoping Santa will be good to me with a Unimat 1... or at least hope the wife will be good to me... will have to be on my best behaviour from here on in.....LOL LOL
court orchard
#149 Posted : 09 November 2012 21:53:15
Unimat!! You'll have to be very good indeed.
#150 Posted : 09 November 2012 21:57:54
LOL LOL .. 36 years of grovelling so think I have mastered the art by now....Flapper
#151 Posted : 10 November 2012 15:15:55
Spent some time very gingerly fairing the hull of the launch using nothing more than a fine grain emery board and lots of patience.. Flapper .. Think I am just about ready to have a go at fitting my first plank... Will post photo's of my planking attempt soon.. In the meantime here are the images of the faired hull....Blink Blink
#152 Posted : 10 November 2012 15:18:58
Hi Alan Everything looks goodBigGrin Regards Mike
#153 Posted : 10 November 2012 15:22:04
Thanks Mike... first plank should be fun...looking forward to it....
#154 Posted : 10 November 2012 18:15:35
First experience of planking has now got underway, have now laid the first plank on either side of the launch. Used an electric plank bender and have to say it worked very well with little effort. Plank set in place using superglue gel.... Now ready to continue when issue 11 comes out and Mr T has done the next session of his official build diary.... Looking forward to seeing what comes next....BigGrin BigGrin .. Hope you like the pics....
#155 Posted : 12 November 2012 00:11:01
Not a happy chappy right now.... warped bow spirit received in issue 10 came out of the glass press earlier tonight all dry and flat..... looked at it now and it has warped worse than it was..after just 2 hours...Cursing Cursing Cursing .... all the other parts have remained flat.... Looks like plan B tomorrow evening, that being a wet tea towel and a hot steam iron.... I know if I fitted it just now the nose of the ship would be pointing to port...LOL ... Oh the joys of model ship making eh..... Update on progress tomorrow.....
Sillvestra
#156 Posted : 12 November 2012 01:16:16
How long did you leave it to dry? Any parts that I've soaked and put in to press have always been left for at least 72 hours to fully dry...
Current Builds:
- HMS Sovereign of the Seas
Planning on Building:
- Scratch built HMS Victory full detail interior (I know what's inside even if you can't see it BigGrin)
Completed Builds:
#157 Posted : 12 November 2012 09:26:49
Hi Sillvestra, parts had been in the press for approx 96 hours... was badly warped to start with.. Just have to go back to the drawing board and try again....Cool
#158 Posted : 12 November 2012 20:54:29
Have now treated the warped bow spirit to a wet tea towel and a hefty going over with a hot steam iron..... Definately an improvement but think it is going to take a few goings over before it is fit for the ship.... Back in the glass press and will check again later.... Hot steam iron appears to be a good way of dealing with badly warped pieces...
Ger C
#159 Posted : 13 November 2012 00:47:55
She looks great a credit to your effort
mark 2
#160 Posted : 13 November 2012 08:19:16
Hi Alan.
Your build is coming on greatly now.
Best regards.
Guest (16)
This page was generated in 0.716 seconds.
