Building fixture Options
Bob Abell
#1 Posted : 10 November 2012 08:52:24
Hello Chaps
You may be interested in my set up?
I`m using my old model aircraft fuselage assembly rig
It uses multi adjustable angle brackets and seems to be ok
This is my first photo posting .....I hope it works!
Bob
DJS
#2 Posted : 10 November 2012 09:14:41
Hi Bob,
Excellent idea, wish I could remember where I left my old one too.
Dave
#3 Posted : 10 November 2012 10:16:34
A great idea Bob to resurrect this jig which is commonly used in model aircraft builds.
Its sold by SLEC, the brackets and self-adhesive grid layout are provided in a kit, all that needs to be provided is a base board and it be drilled.
Item "Building Jig Ref: SL054-S" in this link..
http://www.slecuk.com/ca...ng-Aids.html#aSL057_2dR
Its certainly one to use for the 1/12 scale Spitfire build if and when it comes along
Bob Abell
#4 Posted : 10 November 2012 10:28:56
Thanks, Mr T
I bought the set from Woodvale, twenty years ago and never used it
I knew it would come in handy, one day!
Bob
#5 Posted : 11 November 2012 10:36:38
The only problem is that when you get to issue 11, (when you start to add the deck sections), you'll discover that this jig then becomes redundant, because the jig clamps are much taller than the keel, which means they you won't allow placement of the decks whilst the model is set in the jig, and won't be able to make use of the jig thereafter unless you cut down the bracket heights, which would ruin them for future use on model aircraft builds.
Bob Abell
#6 Posted : 11 November 2012 10:51:18
Thank you, Mr T
You are quite right there, Mr T.....I may cut them down later, as I don`t intend making any more airers anyway!
When the hull has a few planks and decks in place, it should be quite rigid and may take it out of the fixture and invent something else!
All part of the fun?
Bob
#7 Posted : 11 November 2012 10:55:09
The good thing is that it brought something into play that has been laying idle, and indeed al part of the fun Cool
#8 Posted : 11 November 2012 13:23:47
There is indeed a 1/12 scale Spitfire in the system, but time will only tell if and when it might be rolled out here.
Here's a link to it..
http://www.altaya.es/col...nstruye-tu-spitfire.html
#9 Posted : 11 November 2012 14:55:59
Because they developed it and therefore get first bite of the cherry, in the same way that the SotS was developed in Italy and went on sale there first despite it being a UK ship and also the McLaren via Japan..
#10 Posted : 11 November 2012 15:56:34
I wonder if deag have approached jotika? the agamemnon maybe,then we would be first.
