Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
haha i also thought this was shot outside. Looking good! cant wait for more, also those hand planes look interesting, might have to add it on my list of tools to buy ^^ Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi, I just purchased a David's plane and spare blades of Amazon, if that is any help. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Finally got round to starting work on the Garboard plank.... only problem I encountered was twisting the plank to fit the stern... first two planks split and snapped. Finally got the hang of it by simply taking it easy and with patience.... Taper on the bow proved to be fairly straight forward, used map pins to hold the tapered plank in place along the taper and normal pins into pre-drilled .5mm holes for the rest..... Hopefully finish issue 18 tomorrow....  Happy building all.... Gandale attached the following image(s):
Admiral Anti Spiral wrote:haha i also thought this was shot outside. Looking good! cant wait for more, also those hand planes look interesting, might have to add it on my list of tools to buy ^^ Thanks for looking in Admiral.... slow going but progressing... Regards Alan
claret wrote:Hi,
Regards Claret Thanks for the info Claret, have ordered one through CMB, hopefully will be here tomorrow.... thanks for looking in..... Regards Alan
Good job there Alan. Well done. Love all your toys too, makes life so much easier. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hans wrote:Good job there Alan. Well done. Love all your toys too, makes life so much easier. Thanks Hans, appreciate your kind comments.... I love my toys too, problem I have is knowing how to use them.....  ... am sure I'll get the hang of them eventually..... Thanks for looking in... Regards Alan
Thanks for the recommendation Andy, Karl... Davids Plane, plus a few other goodies arrived today and have used it for the first time tonight... excellent tool so think my cute little planes will be used for some rougher work if needed.... thanks again....
Watch your fingers, I've cut a few shavings off mine, over the years  . It's a great tool, but one of the reasons is that it is truly razor sharp.
court orchard wrote:Watch your fingers, I've cut a few shavings off mine, over the years  . It's a great tool, but one of the reasons is that it is truly razor sharp. Thanks Andy, I will watch my digits, am partial to my digits I am..... Regards Alan
Finally finished issue 18.. took a little bit of time but thoroughly enjoying the planking experience... Am hoping to finish issue 19 planking over the weekend and catch up a little..... Am quite pleased with the results so far.... Gandale attached the following image(s):
Have made a start on issue 19's planking.... So far everything appears to be going well and enjoying the task... hoping to finish issue 19 planking tomorrow..... Regards Alan Gandale attached the following image(s):
 Hi Alan doing a sweet job there on the planking keep up the good work regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Alan doing a sweet job there on the planking keep up the good work regards Andy Thanks Andy, appeciate your comments.... am actually enjoying the planking experience, slow and easy and hopefully will pick up pace as experience is gained... Regards Alan
 Your doing it just right not rushing and taking your time, as you do more you will get faster its a learning curve your going through and your coping just fine regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Today I finished the planking up to and including issue 19.... Issue 20 says to add another 3 rows and then do some work on the launch.... will decide tomorrow what I will do.... Am happy so far with the way the planking is looking..... Gandale attached the following image(s):
Hi Alan, Planking looks bril. Nice and steady does it! Claret. Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
claret wrote:Hi Alan,
Claret. Claret, thanks for the kind comment..... being patient certainly helps and I too am enjoying the planking.... The marks you see have been made by the drill chuck and just for my own piece of mind I have marked the location on the bottom deck on planks.... just gives me a visual reference..... Regards Alan
Hi Alan. Looking very nice keep up the good work Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:Hi Alan. Looking very nice keep up the good work Ian. Thanks for commenting Ian, appreciate you taking the time to look in..... Onwards we go eh... Regards Alan
Guest (12)
