162 Pages «<2122232425>»
#441 Posted : 30 January 2013 08:09:33
Steady as she goes Alan. Great job on the launch. Like your way of thinking. Do what works best. Well done.
#442 Posted : 30 January 2013 18:04:43
BigGrin Hi Alan
A very nice job on the launch
#443 Posted : 30 January 2013 23:30:55
Mo wrote:
Sterling job on the launch, Work Work, Busy Busy, Chop Chop, Bang Bang.
Mo 🚣. ⚓
Thanks for the nice comments Mo.... you forgot the Hack Hack....LOL
#444 Posted : 30 January 2013 23:33:33
delboy271155 wrote:
WTG
Like the idea of making up the ship`s boat boarding outside of the build and then fitting.
I followed the official build an found it difficult to get it properly centered, so may remove and redo.
By the way, i have just started a practice planking on the second deck. I am following your excellent tutorial with the black card inserts but have devised a tree nailing process that does away with fishing line as used in some builds,tried it but to difficult with pork sausage fingersLOL .
Will detail in my build in next couple of days hopefully.
In the mean time keep the build and good ideas comingCool
Delboy271155
Thanks for the encouraging comments Derek, appreciate it very much.... Look forward to seeing the results of your decking and of course you tree nailing process.... BigGrin BigGrin
#445 Posted : 30 January 2013 23:34:35
Thanks for your encouraging comments Hans.... trying not to make things difficult for myself..... think then act, always a good motto to have...
#446 Posted : 30 January 2013 23:35:56
BigGrin Hi Alan
Thank you Andy, appreciate your comments and you taking the time to look in... Tonight, just got down to priming all the launch accessories prior to painting..... will be posting again soon.....
#447 Posted : 31 January 2013 00:03:54
Love your launch work Alan! Cool Nice and clean construction.
Even I didn't like the idea of scratch building the things in 1/100 scale so I bought a selection of different sized Amati "Lifeboats" (launches in other words!) the main body is in white metal with supplied strips of good quality wood for the interior details.
Will make a nice little mini projects as a break from the big girl herself! BigGrin
Well done again!
court orchard
#448 Posted : 31 January 2013 01:31:35
Nice Launch, you've inspired me to have a go at mineThumpUp
#449 Posted : 31 January 2013 13:04:33
Hi Alan great job BigGrin Regards Mike
#450 Posted : 31 January 2013 21:58:01
Well done again!
Thanks for the praise Robin, nice to know people look in..... Somehow, I have the crazy tendancy to want to build the launches from scratch, fiddly in places, yes, but the sense of satisfaction I get knowing it has all been put together by me and with care is where I get the most enjoyment..... Nice to know though there is the fallback of MWG's launch kits and of course Amati.... Looking forward to seeing more of your work...
#451 Posted : 31 January 2013 21:59:19
Thanks for that Andy, makes a change for me to inspire you rather than the other way round..... Look forward to seeing what you come up with.....
#452 Posted : 31 January 2013 22:01:01
Thanks for the nice comment Mike, very much appreciated.... Hope things have quietened down enough for you now giving you the time to get back to your builds.... Look forward to seeing more from your diaries.....
#453 Posted : 01 February 2013 22:56:34
Looking for a little bit of advice. I am looking for some good quality paint brushes especially for fine detailed work...... Would appreciate some recommendations on what to get....... Thanks....
court orchard
#454 Posted : 01 February 2013 23:30:44
Kolinsky Sable brushes are the best you can buy and although horribly expensive for larger brushes that artists use, they are reasonably priced for small brushes 2/0, 3/0 etc. they hold paint and release it very precisely. Plus they last for ever if you take care of them. For larger brushes and for washes and dry brushing I use Citadel brushes.
For very fine detail I use a 6/0 brush.
#455 Posted : 02 February 2013 22:20:20
Thanks for the info Andy, I use Admiralty brushes by Caldercraft, I like them very much but still wanted a couple of real good quality detail brushes for doing the real intriquet work such as the black banding around the buckets.... that bit I am having a problem with but will get there in the end...
Thanks again..
#456 Posted : 03 February 2013 00:06:45
Hi there Alan!
Court is correct about the sable brushes, I used to use them many years ago at art college, I've actually got a 4" sable brush which I inherited from a relative, it's as soft as anything but I've never used it with paint however, I just use it for dusting my finished models!!
My current paintbrushes are a mixture of cheapies mainly Humbrol for larger areas (No4), quite a soft brush but not true sable. For the detailed work I am currently using a range of German "Premier" brand "Finest Nylon", a No1 and, for the smallest details, it's either a 0 or a 00 (it's worn off the handle!) All of these are fine pointed at the tips. I bought mine from my local model shop in Plymouth (part of the Antics chain). Nowhere near as pricey as sable but good value for the quality
The only other 'main' brush I am using on the Victory is a Rowney No5 Flat brush, again in nylon for dry brushing the various details.
The main thing with these brushes is not to mix the medium (paint). If you are painting in both acrylic and enamel or other spirit base get a set of brushes for each. I found that nothing ruins the brush tips more than cleaning them in water one time and white spirit etc the next. A good set will last many years as Court said, but only if looked after!
Happy hunting!BigGrin
#457 Posted : 03 February 2013 22:11:53
Plymouth57 wrote:
Hi there Alan!
Thanks Robin, appreciate your input... Not very keen on enamel paints, much prefer acrylic.... am quite happy with the brushes I have but it is the real fine detail where I find the brushes a problem.... am now looking for sable brushes, size 0, 2/0, 3/0, 5/0 and 6/0.... Also have an airbrush on order which hopefully will arrive tomorrow.... Thanks again for your assistance....
#458 Posted : 03 February 2013 22:17:19
Did some work on the launch accessories and fitted the duck boards in place.. decided to add a little detail to the oars and bucket, oars by painting the handles white and adding a walnut brown tip. Also, wasn't too keen on the handle provided for the bucket, think during that period the handles on buckets would be made of rope, so fitted rope instead.... All in all, don't think the pieces turned out too bad.... Tomorrow, will be getting the blackener out and using that on the launch mesh.....
#459 Posted : 04 February 2013 09:40:17
Looking good, love the attention to detail. Makes for great build
court orchard
#460 Posted : 04 February 2013 15:37:48
You seem to be doing fine without the Kolinsky.ThumpUp
Guest (142)
This page was generated in 0.241 seconds.
