Hans wrote:Looking good there Mike. Love the shape. Lots of thought and effort and a fine result, well done. Thank you Hans for looking in  your comments are most welcome Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Great job Mike, I like the balsa filling
Jesus-Belzheim wrote:Great job Mike, I like the balsa filling Hi Peter how are you? thanks for the nice comment  Best wishes Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GARDBOARD PLANKS. Hi Team, I think the instructions are very lacking in certain areas, particularly with the fitting of the Gardboard planks, these are very important pieces of timber and in my opinion should be fitted first, that way you know your keel is straight and true plus fitted now the keel will keep its shape and not move. As I am using 1 metre length lime wood planks,(and thrown all the bamboo in the skip) I must first cut two to size, and as I am going to need the plank to twist at the keel stern, and bend with a slight twist at the bow, I must soak for 30 mins both ends of the plank this is how I did it:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GARDBOARD PLANKS I will be fitting the planks with out adhesive so the wet parts of the planks will dry out and keep their shape, then in 24 hours I will fit the planks using this Aliphatic glue:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GARDBOARD PLANKS I recommend drilling the planks at the point the pins will enter the hull this prevents wood splitting and putting pins in the wrong place. You will see my methods are always slow and precise, I do not rush preferring to take my time and get it right:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GARDBOARD PLANKS And so I first fitted the Starboard plank, please note the plank should fit along the keel stern in line with the edge of the keel not in my opinion as shown in the instructions with a gap sloping down:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GARDBOARD PLANKS And then on to the Port plank, fitting it exactly the same:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FITTING THE GARDBOARD PLANKS Well thats all this time Team, I will be taking my time in planking around the deck until more of the stern upper structure is supplied, in case I have to make more modifictions. When the planks have dried out naturally (I do not like to use electric plank benders)I will fit the planks with the adhesive. Thanks for looking in, questions and comments welcome Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Very nice tutorial there Mike...nice piece of work and a few things there to digest....
Thanks
Hi Mike. Thanks for the great tutorial with great advise  . Keep up the fantastic work. Best regards. Mark
Hello Mike, Good work Mike Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Good tutorial Mike.Hope you don't mind but I would like to ask about something in your pictures.It may be me or a visual effect butwhat would be the portside bow section seems to be stepped away from the rest of the hull,it's almost as if you faired the main hull & then added the bow section.As I said it may just be me or an optical illusion so please don't take offence at my observion. Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Dontshootme wrote:Good tutorial Mike.Hope you don't mind but I would like to ask about something in your pictures.It may be me or a visual effect butwhat would be the portside bow section seems to be stepped away from the rest of the hull,it's almost as if you faired the main hull & then added the bow section.As I said it may just be me or an optical illusion so please don't take offence at my observion. Hi Rob, sorry I am late in coming back to you, I have been in London for three days. It is the way the photograph is taken, the balsa infil on the bow is higher than the infill on the sides (because of the gun port height)I have added a photo which I previously posted on my build log, it shows the difference. No offence taken Rob, your comment was a constructive one  thanks for looking in Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
your doing a nice work here Mike And I`m fine, thanks for asking I hope you too
FITTING THE GARDBOARD PLANKS Hi Team continuing the fitting of two planks either side of the base of the hull. I used hot water to get the twist so the plank would fit properly where it enters the keel area, and at the bow. The photos should tell the story, well here goes:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 04/02/2013 Posts: 31 Points: 23 Location: Pershore
MWG wrote:Dontshootme wrote:Good tutorial Mike.Hope you don't mind but I would like to ask about something in your pictures.It may be me or a visual effect butwhat would be the portside bow section seems to be stepped away from the rest of the hull,it's almost as if you faired the main hull & then added the bow section.As I said it may just be me or an optical illusion so please don't take offence at my observion. Hi Rob, sorry I am late in coming back to you, I have been in London for three days. It is the way the photograph is taken, the balsa infil on the bow is higher than the infill on the sides (because of the gun port height)I have added a photo which I previously posted on my build log, it shows the difference. No offence taken Rob, your comment was a constructive one  thanks for looking in Kind regards Mike well done mike you did a very good job on this model well done.
FITTING THE GARDBOARD PLANKS Well Team that is all for now, I hope you have found my Diary useful  Questions and comments are welcome. I will leave you with 2 photos of the bow with the stem dry fitted. I will not be doing any more planking untill I receive many more issues, so that I can determine if I need to do any more modifications to satisfy the way I wish to build my model Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Exceptionally neat and tidy Mike, again have learned something.... thanks...
Hi mike. Looking good, keep up the excellent work. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Guest (187)
