court orchard wrote:I would think that that is easily enough, my back of an envelope calculations come to about 30m. But better safe than sorry. As you say it'll always come in useful for the next build. Thanks Andy, question is though.... do I trust your back of an envelope calculations..... think I'll play it safe and order more than enough...  .... The bonus would be in giving me a selection of walnut strips to choose from to ensure I get the best colour match..... I also suppose I could class this as my first enhancement.... Regards Alan
A little more progress tonight. Decided to get to work on fitting the brace pieces at the base of the transom.... Started by using 4 off cuts of bamboo roughly the same length... Kept the length deliberately long, this way it gave me something to grip when it came to shaping.... Glued two strips together using PVA and clamped the whole lot together and left to set.. Gandale attached the following image(s):
Took one of the strips and roughly marked the length required. Shaped the strip using a small sanding block with medium grade sandpaper to get the rough shape, then gave it a fine sand.... Once complete then cut to length and filed to ensure a good fit... Gandale attached the following image(s):
Marked and predrilled .5mm holes for the pins. Set the pins in place and finally glued and pinned in place. Will now leave to set prior to final shaping with a fine sanding block... That's tomorrows task together with fitting the other side..... Happy building fellow builders.... Gandale attached the following image(s):
Hi Alan, you are doing a great job of the planking  I am sure you are finding the balsa infills a big help now. Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
MWG wrote:Hi Alan, you are doing a great job of the planking  I am sure you are finding the balsa infills a big help now. Kind regards Mike Mike, thanks for your very positive comments, it is very much appreciated. As for the balsa infills, they have been a great help with the planking and I know I will do the same when I come to start on the Vic. I gained a wealth of knowledge and experience using infills and I know next time I will take a lot more care and do it slightly different. Would I build without it.... probably not.... Thanks for your tutorial on the subject.... brill.... Regards Alan
Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
planking coming along nicely. Work work, busy busy, chop chop, bang bang.
Mo Mo
Mo wrote:planking coming along nicely. Work work, busy busy, chop chop, bang bang.
Mo Thanks Mo.... as they say.. the end is neigh...at least for the lower hull.... Regards Alan
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Looking good Alan. A credit to you. I am a couple of issues behind, but will not be able to work on her until the weekend. Interesting comments about not using the basswood strips supplied but use more walnut. Undecided yet Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
claret wrote:Looking good Alan. A credit to you. I am a couple of issues behind, but will not be able to work on her until the weekend. Interesting comments about not using the basswood strips supplied but use more walnut. Undecided yet Regards Claret Thanks for your very ncie comments Claret and as usual thanks for tking the time to look in.... My intention is simply to replace the basswood strips with Walnut strips, leaving the top half done in Sapele... think I will keep the red band with black painted wales, not sure yet, just thinking out loud..... Regards Alan
This is looking very good, I hope to subscribe to this one soon (if the wife dosent find out) dont think i can wait till my Vic is finished though after seeing all the builds of the SOTS. I never realised what a nice shape the hull is on this one. Cheers Steve
stevie_o wrote:This is looking very good, I hope to subscribe to this one soon (if the wife dosent find out) dont think i can wait till my Vic is finished though after seeing all the builds of the SOTS. I never realised what a nice shape the hull is on this one. Cheers Steve Thanks for looking in and the nice comments Steve.... she is a lovely build, thoroughly enjoying it and yes I agree. she has very nice curves and shape... Hope you do subscribe as I'm sure you will enjoy putting her together.... Regards Alan
Started on issue 25 tonight by working on fitting the two small wedge pieces to one side of the stern.. This took a fair amount of time not only using steam to get the correct profile but after shaping I found it still wouldn't sit right  , not until i chamfered the joining edge of the planks... Perserverance got me there in the end and have to say I am pleased with the final results, well worth taking my time over.....  Should sand nicely... Gandale attached the following image(s):
Alan, Well what can one say except, "WOW" I have stock piled my planking supplies and start tomorrow, as I have also just started the Victory to fill in delivery gaps. Hope my hull planking turns out as good. Keep up the good work and keep the diary coming, WTG. Regards Delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Alan, Well what can one say except, "WOW" I have stock piled my planking supplies and start tomorrow, as I have also just started the Victory to fill in delivery gaps. Hope my hull planking turns out as good. Keep up the good work and keep the diary coming, WTG. Regards Delboy271155 (Derek) Thanks for the very nice comments Derek. I have loved every minute I have spent so far building this and am pleased with how it is going. Enjoy the planking experience but most of all, take your time and don't try to short cut or rush.... Am sure you will do a wonderful job judging by your build so far.....  Thanks for looking in and commenting, appreciate it very much.... Regards Alan
 Hi Alan Your taking to this like a duck to water m8,Yes you have had some technical problems but your doing fine with the learning curve. Keep up the good work regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Alan Your taking to this like a duck to water m8,Yes you have had some technical problems but your doing fine with the learning curve. Keep up the good work regards Andy  Andy, thank you for that very positive comment, from someone with your experience it means a lot...  ... Don't know about a duck to water..... more like a duckling flapping around trying to learn to swim....  simply loving it though... thanks again... Regards Alan
More of issue 25 planking done today.. Got the two small wedge pieces fitted to the other side of the stern, again fiddly but worth the time spent. Also managed to fit two complete rows of planks to either side of the hull. Found I got a much better fit between the planks when I chamfered the joining edge of the new plank.... Happy with the results so far. Tomorrow hopefully will get the last row fitted on either side just leaving the work on the lauch for the rest of this week.... Happy building all and thanks for looking in.... Alan Gandale attached the following image(s):
And of course the bow and a complete image .... Gandale attached the following image(s):
WTG M8, That is looking real good. Just got into my planking today and as testing as it is for a first timer, WOW it`s FUN and I was really worried before I started, but now just nervous. Keep it going Regards Delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Guest (114)
