Not too much done today, simply finished off the planking for issue 25.... no real problems. Will now be working on the launch prior to the next issue and keeping up to date on all the other builds..... Regards Alan Gandale attached the following image(s):
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Alan! Nice work, well done! It looks like a clean job you made. And - keep cool, it´s sunday, the day for recovery and not to work too much. Always think your SotS is nearly finished, only 110 issues to go Regards, Bernd
der Gohfelder wrote:Hi Alan! Nice work, well done! It looks like a clean job you made. And - keep cool, it´s sunday, the day for recovery and not to work too much. Always think your SotS is nearly finished, only 110 issues to go Regards, Bernd Thanks for those kind comments Bernd, appreciate you looking in..... Sunday!!! is there ever a day of rest with this hobby.... not if you're hooked there isn't.....  ... Thansk again Regards Alan
Hi Alan, I agree with Andy, you are doing a fine job  keep up the good work  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
MWG wrote:Hi Alan, I agree with Andy, you are doing a fine job  keep up the good work  Kind regards Mike Thanks Mike, appreciate the nice comments. Regards Alan
Hi Alan. Fantastic, really nice clean build. Looking forward to seeing more of your build. Keep up the excellent work ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
Fantastic work alan, looking good! Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
ian smith wrote:Hi Alan. Fantastic, really nice clean build. Looking forward to seeing more of your build. Keep up the excellent work ian Thanks for the very nice comment Ian, appeciated.... No doubt will be posting a lot lot more as time goes on, just hope it all turns out the way I want it to.... Regards Alan
Admiral Anti Spiral wrote:Fantastic work alan, looking good! Thanks Admiral, alway appreciate you looking in and passing comment..... makes it all worthwhile.... Regards Alan
Brilliant job there Alan. Time, effort and patience is paying off. Well done. Keep it up we will be watching closely, for times to come. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hans wrote:Brilliant job there Alan. Time, effort and patience is paying off. Well done. Keep it up we will be watching closely, for times to come. Thank you for the very nice positive comments Hans, appreciated very much.... Have made a start on the planking for issue 26, have laid one row so not worth posting pics for the little progress made. Hopefully will post pics tomorrow.... Regards Alan
Hi Alan  , Did you decide to source some rum barrels  , I looked again at the scale and 00 railway scale is not 1:72 it`s 1:76 so it`s even closer to 1:84 than I thought. Keep it coming, loving it  . Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Hi Alan  , Did you decide to source some rum barrels  , I looked again at the scale and 00 railway scale is not 1:72 it`s 1:76 so it`s even closer to 1:84 than I thought. Keep it coming, loving it  . Regards delboy271155 (Derek) Hi Derek, not yet but am going to order a batch.. have all the details you gave safely stored away for when needed.... Thanks for the info... Regards Alan
Onwards we go and tonight I tapered the planks as detailed in the mag and Mr T's official build.... tapered the upper edge of the new planks to get as good a fit as possible, think it worked out very nicely... 2 rows completed and now left to dry before continuing..... Gandale attached the following image(s):
While waiting for the planks to set thought I would finish the evening by fitting the painted thwarts to the launch.... Gandale attached the following image(s):
Hi Alan! You are very busy, first planking is nearly done! It´s like always a really nice work, respect! Are you pulling the nails out after drying? Regards, Bernd
der Gohfelder wrote:Hi Alan! You are very busy, first planking is nearly done! It´s like always a really nice work, respect! Are you pulling the nails out after drying?
Regards, Bernd Thanks for looking in Bernd..... I like to spend a little while in the evening working on the old girl, helps me wind down from a days work.... All pins are pulled out when the PVA has dried, this needs to be done or problems will occur when it comes to sanding smooth.... I think the hull is going to sand down very nicely but may have to use some filler on some small areas, will just have to wait and see how it finally works out.... think 2 more weeks and the lower hull will be covered..... Regards Alan
This weekend I finished the planking up to issue 26 with no major problems encountered... Worked out I only have 5 more rows of planking to go to finally complete the lower hull with the first layer. Also took the opportunity to trim up the stern section a little.... Only leaves me with the work to carry out on the launch before the next issue on Wed... Happy building to all..... Regards Alan Gandale attached the following image(s):
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Nice neat job there, well done HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
moriarty wrote:Nice neat job there, well done Thanks for the nice comment Moriarty, long ways to go yet eh!... Regards Alan
Guest (169)
