40 Pages «<2829303132>»
MWG build diary of HMS Sovereign of the Seas Options
Jesus-Belzheim
#581 Posted : 30 March 2013 15:31:28
Great work Mike ThumpUp
And Yes, the package has arrived
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#582 Posted : 30 March 2013 19:05:22
Admiral Anti Spiral wrote:
great work mike! as bernd said, very nice and clean work there, keep it up!
Thanks Admiral, I appreciate you looking inBigGrin Kind regards Mike
#583 Posted : 31 March 2013 14:59:49
High standard of work once again Mike, very well done......BigGrin BigGrin
Hi Alan thanks for looking in and for your nice commentsBigGrin Happy Easter Mike
#584 Posted : 31 March 2013 15:10:10
Taking shape Mike..Love it mate!! ThumpUp
#585 Posted : 31 March 2013 20:34:37
Thanks PeterBigGrin Happy Easter Mike
#586 Posted : 01 April 2013 02:46:22
Thanks Jonny for the nice commentBigGrin A happy easter to you, Mike
#587 Posted : 01 April 2013 16:39:18
FITTING THE DUMMY GUN SUPPORT BEAMS
Hi All, you will notice I have done very little planking, I have concentrated on making sure the basic construction of the ship is to my liking.
During this process I noticed 3 ribs were off line so I cut them off and realigned them.
At this stage I can access parts of the ship easily, particularly when it comes to fitting the stern gun ports, which I want to have open not closed.
I have fitted the Dummy gun support beams, while doing this I pinned the beams through to the ribs,to make a stronger fix, plus I ran a good layer of adhesive along the back of the beam where it comes in contact with the deck, here are the photos:-
#588 Posted : 01 April 2013 16:47:01
Well thats it for this session, this is how the ship looks at the momentBigGrin Thank you for looking in,Kind regards Mike
#589 Posted : 02 April 2013 00:36:44
Hi Mike.
Looking very good with stern fitted.look forward to seeing more.
Keep up the good work ian CoolCool BigGrin
#590 Posted : 02 April 2013 08:51:48
ian smith wrote:
Hi Mike.
Hi Ian thanks for the commentsBigGrin I hope you had a nice Easter best wishes Mike
#591 Posted : 02 April 2013 10:42:48
Looking good there Mike. Just a quick question, what method of steaming do you use??
#592 Posted : 02 April 2013 11:24:26
Hi Hans, if I am just steaming I do it over a kettle, but usually I prefer to soak wood for 30 minsBigGrin I hope that helps, Kind regards Mike
skyfire
#593 Posted : 02 April 2013 11:29:42
Hopefully one day I will get to build this ship, only I have no idea where I would keep it. Looks like I would have plenty of room for some LED lighting through the ship. Looking good. :)
#594 Posted : 02 April 2013 12:23:30
Hi Sky Thanks for looking inBigGrin There is lots of room for a lighting project, but I agree we all need more roomBlink Huh Kind regards Mike
#595 Posted : 03 April 2013 09:56:39
Hi Hans, if I am just steaming I do it over a kettle, but usually I prefer to soak wood for 30 minsBigGrin I hope that helps, Kind regards Mike[/quote]
Thanks Mike. I have a small electric steamer whioh I bought years ago. Will give it a try and see how it goes. Thanks.
jpda
#596 Posted : 14 April 2013 23:22:05
Rank: Beginner Level 3
Red Medal: Red Medal
Very nice progress on your build there mike.
Jay
NMBROOK
#597 Posted : 15 April 2013 00:32:25
Mike you may encounter a problem marking out the gunports as the cannon support beams are now fitted on the middle deck.The instructions will say to drill tiny holes from the inside in line with the top of the middle deck through the planking.This would enable you to mark the edge of the deck on the outside of the planking.All of the dimensions we are given for the gunports use the top face of this middle deck as a datum.All i can suggest is that when you do the first planking you make the top edge of a plank flush with this deck.You will then have a line to follow on the outside.
Regards Nigel
#598 Posted : 15 April 2013 19:19:48
Jay
Hi Jay thank you for your kind commentsBigGrin Best wishes Mike
#599 Posted : 15 April 2013 19:30:46
Regards Nigel
Hi Nigel,
I am not following all the instructions with my build, I am adding my interpretation of how the ship should look i.e. Offset bowsprit, deeper shaped hull at the stern,rear open gun ports and stern(transom) opening gun ports.
I will be cutting my gun ports at 12mm square (not 13) as this will represent a better scale size in my opinion. I will be adding frames for my gun ports and planking up to the exact measurements, with no need to cut out, as they will automaticaly appear as the planking is fitted.
I hope this answers your question.
I am looking forward to seeing your build,BigGrin thank you for looking in
Kind regards MikeBigGrin
NMBROOK
#600 Posted : 15 April 2013 20:01:21
No worries mate just didn't want you to end up in a pickle,but you've obviously got it covered.My gunports are all cut but if i was to do the build again I'd drop the lower ports by 5mm the gap between bottom and middle ports is to small as designed by deag.
Regards Nigel
Guest (128)
This page was generated in 0.193 seconds.
