http://www.bbc.co.uk/new...land-hampshire-22691645
Henry VIII's lost men;
http://www.dailymail.co....museums-exhibition.html
The Jotika Mary Rose kit has been designed with the full co-operation of the Mary Rose Trust, making the kit the only model based on the most up to date research and information. The kit is, therefore, the most accurate of its type on a Tudor Warship.
http://www.jotika-ltd.co...4768/Heritage_Front.htm
Its a loverly looking model as well “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Mr T, Thanks for some good links and as for the model "Wow" all I got to try and do now is justify a fourth build to the better half Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Hi Mr T, Thanks for some good links and as for the model "Wow" all I got to try and do now is justify a fourth build to the better half Regards delboy271155 (Derek) Hi Del, I also fancy building the Mary Rose.However if you are planning to buy the c/craft kit I would wait and see if it gets updated.All previous research into the forecastle is incorrect as they have only recently discovered another section of deck in the solent.This means the Mary Rose was one deck higher at the forecastle giving her an appearance nearer to that on the famous tapestry. Kind Regards Nigel
NMBROOK wrote:delboy271155 wrote:Hi Mr T, Thanks for some good links and as for the model "Wow" all I got to try and do now is justify a fourth build to the better half Regards delboy271155 (Derek) Hi Del, I also fancy building the Mary Rose.However if you are planning to buy the c/craft kit I would wait and see if it gets updated.All previous research into the forecastle is incorrect as they have only recently discovered another section of deck in the solent.This means the Mary Rose was one deck higher at the forecastle giving her an appearance nearer to that on the famous tapestry. Kind Regards Nigel Hi Nigel Thanks for that info, don`t think that this build will be imminent as the other half seemed to be putting other ideas in the way.  Holiday cruising the Nile for eight days was top of the list, now I`m between the rock and the hard place. Oh ok holiday wins Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:NMBROOK wrote:delboy271155 wrote:Hi Mr T, Thanks for some good links and as for the model "Wow" all I got to try and do now is justify a fourth build to the better half Regards delboy271155 (Derek) Hi Del, I also fancy building the Mary Rose.However if you are planning to buy the c/craft kit I would wait and see if it gets updated.All previous research into the forecastle is incorrect as they have only recently discovered another section of deck in the solent.This means the Mary Rose was one deck higher at the forecastle giving her an appearance nearer to that on the famous tapestry. Kind Regards Nigel Hi Nigel Thanks for that info, don`t think that this build will be imminent as the other half seemed to be putting other ideas in the way.  Holiday cruising the Nile for eight days was top of the list, now I`m between the rock and the hard place. Oh ok holiday wins Regards delboy271155 (Derek) Twisted your arm eh Del  My wife actually said to me"why can't you make a model of the Mary Rose?"so looks like I am being forced into it Kind Regards Nigel
