 Rank: Pro Groups: Registered
Joined: 25/03/2010 Posts: 100 Points: 289 Location: derby
Hi everyone
I am stuck with the planking on the launch and I really need some help please.
How do I get the planks to stick on the keel I cannot hold all of it at one time, especially as you have to bend it.
Please help me pictures would help as well.
Many thanks Pam
 Rank: Vice-Master  Groups: Registered
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
Hi Pam First of all, bending the planks. The planks on the launch are so thin that a minute's soak in cold water is sufficient to allow you to bend the plank using gentle pressure between forefinger and thumb. Before trying to fix the planks make sure you have chamfered the edges of the ribs so that the planks lie true to the shape of the boat without the planks trying to go in or out too far. Also there is no such thing as a plank with parallel sides when you construct a rounded hull. You will need to shape the planks as you go along so that when they are bent towards the previous plank they can lie true to the edge of the previous plank. The planks can be attached with thick super glue from Cornwall Model Boats or something similar. Start at one end and wait until the first couple of ribs bond with the plank. Then applying the glue to two or three ribs at the time, work your way along waiting for the glue to bond. It's not quick but will give you a good result. You are asking for photos, have you seen Launch Constructionor had a good look at Tomick's official Victory build? Hope all that helps, looking forward to pictures of yourt launch! Mike T.
Thanks Mike So its little and often...... If I damage a plank can I get any spares --if so what size do I order. This is only the beginning of the build and I am stuck -getting worried about the rest, I am so glad we have the forum.......
Think positive! Don't damage the planks! Yerr right we all have problems, however there appears to be a comfortable surplus for the launch, so let's hope you don't need any extra
Mike T
phew re planks
Joined: 17/03/2010 Posts: 128 Points: 336 Location: Windsor, Berks
Don't worry Pam I'm in the same boat as you, haven't got a clue how to do it I've even got 2 launches, one to pratice on Follow my build to learn how to make firewood
That's a great idea I am also struggling with my cannonade I have small fingers I don't know how you lads get on with the little bits and bobs. I am seriously thinking of sub letting my little models out and asking someone to build them for me. Anyone interested Pam
Joined: 02/04/2010 Posts: 491 Points: 1,460 Location: Poole
pamlupo wrote:That's a great idea I am also struggling with my cannonade I have small fingers I don't know how you lads get on with the little bits and bobs. I am seriously thinking of sub letting my little models out and asking someone to build them for me. Anyone interested Pam Are you wealthy? *twiddles moustache* Whilst I have been known to *Ahem* 'pimp' my services about, I admonish you to bite the bullet and get stuck-in yourself! I too was a little apprehensive before following the mag build but it proved more do-able than I had first thought. Mike T's instructions are enlightening so do have a look at them. Once you have the jig built, keep dry-fitting planks to show you where you need to contour the formers - being especially careful when sanding, given the fragility of the formers - you don't want to go snapping them Just take your time with every single plank.Dry fit everything first to see where you might need to alter something or to get a warning of future 'challenging situations'* where extra attention might be required (*These used to be called 'problems' back in the day, but since we are all politically correct and 'positive' now, I shall use the modern tongue). Oh... and before I forget.. Just take your time with every single plank.Schnellboots on back burner
Tools.
will do and will let you know how I get on. Thanks everyone for the support P
Capt Stedders wrote: but since we are all politically correct
Speak for yourself sir!! Never let it be said that I am what you quote !! Damme, will have to take a glass of Port to recover!! Seriously Pam do what Stedders says and just give it a go the idea of him twiddling his moustache and pimping fills me with dread! Mike T
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
The only PC I know is the one i'm sat in front of & the ones I fix!!! Seriously though,all this political correctness does my head in at times..who has ever seen a rainbow sheep...unless it's with the aid of some falling down water of course!! Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Joined: 20/04/2010 Posts: 141 Points: 426 Location: Worthing, United Kingdom
dedworthdog wrote:Don't worry Pam I'm in the same boat as you, haven't got a clue how to do it I've even got 2 launches, one to pratice on A practise launch? I see my launch as the practise for the Victory herself!
 Rank: Newbie Groups: registriert, Registered Joined: 28/04/2010 Posts: 1 Points: 3 Location: buxton
just a query about the launch construction would it not have been clinker built
one of victory's boat's is clinker built but the rest are planked i'm affraid, so keep practicing Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Joined: 28/03/2010 Posts: 152 Points: 513 Location: Liverpool,England
karl1113 wrote:one of victory's boat's is clinker built but the rest are planked i'm affraid, so keep practicing What does clinker built mean please ? Jimmy Jimmy L.
current builds : Lancaster 1/32 (Hachette) Revell USS Kearsarge Titanic Lifeboat
Planks overlap each other instead of edges butting up together,commonly known as Carvel see this example which shows both types  Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
cheers Rob, I understand now. Jimmy Jimmy L.
Joined: 07/06/2013 Posts: 144 Points: 415 Location: New Zealand
Having a pig of a problem with this ship. mostly the launch. Thought I'd lay the keel first as I thought this would help with the planking, when I reached that point. I'm glad that I tried it before I glued it, as I always do. The different heights and widths of the ribbing is amazing for something that was precision cut. At fist I thought I'd put them (ribbing) in the wrong order.
Joined: 10/10/2010 Posts: 691 Points: 2,136 Location: Dorset
Hi Pam. Like you I was new to this type of build, but being retired and with "nothing to do" I decided to have a go at the Victory. I know exactly how you feel, the magazine build instructions are not as clear or comprehensive as they might be so refer to the build diary as this will be a great help. As you have already done ask questions on this forum. Someone will always be willing to answer/guide you as they have me It is not a quick build so you will need patience and perseverance. Good Luck with your build I have reached the heady heights of issue 120 so am nearly there. Pictures attached GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
That build looks absolutely brilliant. You should be rightly proud of producing such a wonderful piece of work. Happy Modelling
