Wood Supplies in SA Options
KobusBeukes
#1 Posted : 10 June 2013 15:55:13
I've noticed that the guys are making use of different kinds of wood in the build of which is not supplied with the kit.
Where in South Africa can you find wood such as box, lime, pear and maple in quantities big, or must I say small, enough for model building?
Or must we import if we want to go the same route as eg Nigel or Alan?
Kobus
Current Build
KobusBeukes
#2 Posted : 11 June 2013 20:08:28
The following wood is available from the Model Dockyard and are use extensively by the UK builders.
"Beech Strip, Flexible Beech Strip, Cherry Sheet, Lime Dowel, Lime Sheet, Lime Strip, Mahogany Strip, Mahogany Sheet, Maple Strip, Maple Sheet, Plywood, Pear Sheet, Tanganyka Strip, Tanganyka Sheet, Walnut Dowel, Walnut Sheet, Walnut Strip, Walnut Profile Section, Half Round Wooden Dowel, Display Case Section and Premade Wooden Decking"
Are there no such place in South Africa to buy these sizes from?Confused
Kobus
Current Build
Grizzly
#3 Posted : 11 June 2013 21:45:16
Kobus, Try Silverton Timbers, they have all sorts of imported timbers.
You'll have to cut it to size yourself but that's not difficult.
All the best, Grizzly
KobusBeukes
#4 Posted : 12 June 2013 05:55:47
Hi Grizzly
Thanks for the info. I will contact them.
Kobus
Current Build
Karelkat
#5 Posted : 16 June 2013 22:03:29
Rank: Newbie
I know for certain Jix hobbies in pretoria supply the wood. They are located in menlyn retail park across menlyn mall.
KobusBeukes
#6 Posted : 16 June 2013 23:00:37
Hi Karelkat
Thanks for the info, will definately visit them.
Kobus
Current Build
Castos
#7 Posted : 20 June 2013 05:10:55
Hi Kobus
A lot of experience builders cut their own wood, using a band saw, circular saw and a thicknesser.
Look at the following sites where there is a lot of information.
http://mysite.verizon.net/ELLshipmodeler/
http://mysite.verizon.ne...Lshipmodeler/lumber.htm
At modelshipworld and modelshipbuilder there is a wealth of information available.
Hope this helps.
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
KobusBeukes
#8 Posted : 20 June 2013 05:56:49
Hi Castos
Thanks very much for the info, will definately make use of it!LOL
Kobus
Current Build
KobusBeukes
#9 Posted : 07 July 2013 18:53:46
Got some wood from Jix Hobbies in Menlyn yesterday, i.e. walnut, cherry and yellow heart. The size is 3 x 75 x 600 mm (1/8" x 3" x 24"). They also have a 1/16" thickness.
Kobus
Current Build
Marcel
#10 Posted : 12 August 2013 19:16:08
A cheaper way is to direct import from UK. I found this friendly site which fulfill al my wood needs for modeling.
All types of wood ideal for model builts
