Hi All, I have just marked out the top edge of my hull planking and have a question. Does the top edge between Rib#7 and Rib#16 have a slight curve to it, while all the other top edges are a straight line? Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 27/02/2013 Posts: 228 Points: 664 Location: Bursledon
I started with the first plank following the curve of the second deck. All of my subsequent planks are following that curve, all down the sides. Did I do this wrong?
Captain David wrote:I started with the first plank following the curve of the second deck. All of my subsequent planks are following that curve, all down the sides. Did I do this wrong?
Hi Cap`n, No you done nothing wrong, I am questioning where we cut the top level of the planking. regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
Hi Derek I found that the upper level at the fwd end has a slight curve downwards from fwd to aft. then the lower level at mid ships (the bit you are talking about) has got a curve, dipping in the middle, this should follow the same curve as the gun ports. I found the next rise also has a curve similar to the midships, then the last two rises seamed to be straight. If your worried you could always leave a bit on to take off later. Hope this helps. Cheers Stu
stujue wrote:Hi Derek I found that the upper level at the fwd end has a slight curve downwards from fwd to aft. then the lower level at mid ships (the bit you are talking about) has got a curve, dipping in the middle, this should follow the same curve as the gun ports. I found the next rise also has a curve similar to the midships, then the last two rises seamed to be straight. If your worried you could always leave a bit on to take off later. Hope this helps. Cheers Stu, That about bears out what I`ve got. The fore section curve is so slight it`s hardly noticeable, the stern sections are straight, but the midships section has a curve. Many thanks for looking in and giving your advise. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
