Plymouth57 wrote:Congratulations Alan! A superb job there and the effects of the planking and curves are beautiful! (And a very belated Happy Birthday / Easter / last Christmas to you too!)  Roll on the POTS Pt.2! Robin Thanks Robin for your very nice comments, they are always appreciated.... Think she will look even better when treenailed, sanded down and has it's coat of varnish..... Regards Alan4
court orchard wrote:Lovely work Alan. I know what you mean about the 2nd Planking, seems to take forever, I'm just beginning the second side. But worth taking time over, if you want it to look good. It's so easy to rush it and then suffer having to look at it for evermore, with regret that you didn't give it enough care. Thanks for the kind comment Andy and yes it does seem to taker forever, think I took about 4 weeks in total to plank both sides of the lower hull.... Couldn't agree with you more, take your time and the results you want will appear and knowing the standard you set yourself then I'm sure yours will look fab.... Kind Regards Alan
stujue wrote:fantastic job Alan. Looking really good. Cheers stu Thanks Stu, appreciate you taking the time to look in and comment.... Regards Alan
Thank you for the very kind comment Nigel, not a patch on your work but appreciate you taking the time to look in and comment.... Best regards Alan
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
well done on finishing the planking of the ship alan! looks great, a beautiful job finally done! Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Gandale wrote:Thank you for the very kind comment Nigel, not a patch on your work but appreciate you taking the time to look in and comment.... Best regards Alan Don't be silly Alan my first planking job wasn't in the same league as yours Kind Regards Nigel
Hi Alan. Looking Superb. keep up the goood work. look forward to seeing your progress ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Admiral Anti Spiral wrote:well done on finishing the planking of the ship alan! looks great, a beautiful job finally done! Thank you very much Admiral, appreciated...  .. Started treenailing this evening, got all the holes drilled with a .6mm drill and am about one third the way along with the cocktail sticks..... A couple of evening should see the job done..... Regards Alan
ian smith wrote:Hi Alan. Looking Superb. keep up the goood work. look forward to seeing your progress ian Thanks for the support Ian... am happy now the lower hull is finally planked with the 2nd layer..... Regards Alan
Hi Alan, Top job of the planking  you should be proud of your achievement!! Did you get the PDF I sent you by email? Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
MWG wrote:Hi Alan, Top job of the planking  you should be proud of your achievement!! Did you get the PDF I sent you by email? Kind regards Mike Thanks for your kind support Mike, nice to see you back on the forum and yes I did get your PDF so thanks for sending it on to me.... Still engrossed in treenailing and am about two thirds of the way through it... hoping to finish it off by Thurs evening.... Regards Alan
At long last the marathon is over and have now completed the treenailing of the lower hull.... talk about a brain numbing task but still loved it.....  .. I must be cookoo!!!!!! Regards Alan Gandale attached the following image(s):
Have now started the sanding process which will be completed tomorrow evening....  .. Then I can hopefully get to work on the gallery and finishing the 2nd planking of the upper hull... Regards Alan Gandale attached the following image(s):
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
Looking good Alan  You will be able to do something more interesting and less tiresome shortly Kind Regards Nigel
NMBROOK wrote:Looking good Alan  You will be able to do something more interesting and less tiresome shortly Kind Regards Nigel Thanks Nigel and that is something I AM looking forward to, hopefully gallery tomorrow evening..... Regards Alan
Nice one "enjoy" Cheers Stu
Have now sanded down and cleaned up the hull as far as I want to at this stage....  .. Am happy with the treenailing albeit not perfect in places but can certainly live with it. Big learning curve and now know the pitfalls to look out for...  Will be having a rethink on the process to make sure it is improved when it comes to my next build....  .. All in all I don't think I have much to complain about.... Regards Alan Gandale attached the following image(s):
