162 Pages «<6667686970>»
stujue
#1341 Posted : 13 July 2013 15:34:00
paint work looks very tidy Alan.
BigGrin BigGrin
Cheers Stu
#1342 Posted : 13 July 2013 22:58:00
KobusBeukes wrote:
Hi Alan
The paint job looks realy nice.BigGrin
Well done!
Thanks Kobus, I'm pleased with it....Cool
#1343 Posted : 13 July 2013 22:59:04
Admiral Anti Spiral wrote:
every new step and it looks better and betterBigGrin great work!Drool
Thanks Admiral, am just simply tip toeing my way through.... BigGrin BigGrin
#1344 Posted : 13 July 2013 23:00:40
BigGrin BigGrin
Thanks Stu, thanks for commenting and looking in... appreciate your support.... Cool Cool Cool
#1345 Posted : 14 July 2013 01:47:58
BigGrin Hi Alan
looking the part now and congrats on showing that using an airbrush is not beyond any beginner with the correct advice
#1346 Posted: : 14 July 2013 07:52:46
Hi Alan, she is coming on in leaps and bounds,great job of the paintingBigGrin the build is a credit to your skills, top work!!! best wishes Mike
#1347 Posted : 14 July 2013 23:00:45
BigGrin Hi Alan
Thanks for the encouraging comments Andy, always appreciated your support.... Cool Cool .. Have to agree with you on the airbrush, I spent some time building up the basic knowledge from people on this forum, from watching countless tutorials on youtube as well ask practicing on an artists pad before being confident enough to let it anywhere near the build....Blink Blink Blink .. All in all it was time well spent and would recommend any newbie do the same....Cool Cool
#1348 Posted : 14 July 2013 23:13:26
Thank you for your very warm comments Mike, always appreciate you looking in. Had noticed you had been rather quiet of late....Cool Cool .. Hope everything is well with you and that your normal service and builds will resume very soon.....Cool Cool
Best regards....
#1349 Posted : 15 July 2013 23:24:17
Have done as much as I want to do at this stage of sapele planking on the transom... Took the advice of Nigel and reduced the size of the planks to a width of 3mm, this I found invaluable as the thinner planks made it a lot easier to follow the profile....Cool Cool ..
When the planking had cured I then got down to the business of trimming the edges and around the gunports, still have a little left to do with the bottom edge but that will be done a little later along with a little touch up of the edge of the burgundy strip at the transom edge....Blink Blink .. Treenailed the section then gave it a fine sanding to finish it off for now....BigGrin BigGrin
NMBROOK
#1350 Posted : 15 July 2013 23:29:16
Looking brill AlanBigGrin BigGrin Nice workCool Cool Did you see the post on my log about using an x-acto blade container as a sanding block for the tight radius at the top?
Kind Regards Nigel
#1351 Posted : 15 July 2013 23:30:05
Started work on fitting the keel, first thing I did was to remove the keel sections from the fret and finely sanded the black ash off all of the edges... Then planked the top edges with 5 x .6mm walnut and clamped in place until dry....Cool Cool .. Once dry I then trimmed and sanded the walnut flush with the keel sections...Cool Cool
#1352 Posted : 15 July 2013 23:34:05
As with the stern post I am covering the keel sides from 1mm sheet walnut... From the keel sections I then drew round each of the sections, giving two pieces of each for each side.... Cut the pieces out using my Unimat...BigGrin BigGrin
#1353 Posted : 15 July 2013 23:37:15
Finally for this evening I dry fitted the keel to ensure I had a nice fit between all the joints....BigGrin BigGrin .. Next job is to fix the keel in place, attach the walnut coverings and finally trim and sand to finish....Cool Cool
Happy building all....
NMBROOK
#1354 Posted : 15 July 2013 23:37:50
Hi Alan you have me curious now,I assume that above the waterline of the prow is going to be painted black,as to why you didn't run the strip all the way along to the prow tip?Do you have something else in mind?I know mine stops at the waterline,but I have some black boxwood sheet to do mine in.
Kind Regards Nigel
#1355 Posted : 15 July 2013 23:48:34
Kind Regards Nigel
Thanks Nigel and thanks for the tips... I did see your post but unfortunately I do not have an x-acto blade container so I simply used my finger tip covered with the fine sandpaper.... finger got hot though....LOL LOL .. Have a little left to do to finish it off but not much.....BigGrin BigGrin ..
Thanks again..
NMBROOK
#1356 Posted : 15 July 2013 23:55:31
Slow down Alan can't keep up with these postsLOL LOL only nipped out for some milk,if I'd have gone to the chippy you would be fitting sails when I got backLOL LOL LOL LOL LOL LOL Did you read my other post?
Kind Regards Nigel
#1357 Posted : 15 July 2013 23:55:57
Kind Regards Nigel
Eagle eyed Nigel spotted it....LOL LOL Flapper Flapper .. truth be told I ran out of walnut strips to take it all the way to the end but have more wood on order.... as the top half of the prow will be painted I just thought it was a good place to stop for now, have some basewood strips of the same thickness so will use that painted black.... BigGrin BigGrin .. Am also contemplating whether to actually cover all of the prow with walnut and still paint the top part black or to stop with the shorter pieces, just not too sure what effect if any it may have later in the build... Think I would like to cover the whole thing and have enough walnut sheet to do the job....BigGrin BigGrin .. Food for thought....
#1358 Posted : 15 July 2013 23:58:08
Kind Regards Nigel
LOL LOL LOL .. Do try to keep up Nigel....LOL LOL Flapper Flapper LOL LOL
NMBROOK
#1359 Posted : 16 July 2013 00:02:53
Ah ha you did read itLOL LOL I would go with what you said,in that if you do cover with walnut,you leave your options open.You can make your mind up later,then you have the option to leave the area under the beak in natural wood if you so desire.You can always clad those little bulkheads with walnut,or remake them out of 4mm walnut sheet.
Kind Regards Nigel
Admiral Anti Spiral
#1360 Posted : 16 July 2013 00:10:24
wow lovely work alan, coming along great, i may have to copy you on that 1mm sheet although in mapleBigGrin, keep up the good workBigGrin BigGrin
Processing - Progressing
Previous builds: HMS Victory
Guest (9)
This page was generated in 0.374 seconds.
