162 Pages «<6970717273>»
#1401 Posted : 22 July 2013 00:06:58
Admiral Anti Spiral wrote:
Very stunning alan, with the work you've done its setting to become a top quality ship buildBigGrin Love
Wow, thanks very much for that comment Admiral.... Have learnt lots so far and still have masses to learn yet and am doing all I can to ensure this will be a successful build...Cool Cool .. So much so I now have other modifications in mind as we move forward but as yet they are mostly cosmetic and not structural.... structural mods will be attempted on my next build.....BigGrin BigGrin
Thanks again, appreciated...
claret
#1402 Posted : 22 July 2013 11:13:33
Hi Alan,
Love the modsDrool
I have been practicing with the spray painting on a large sheet of ply I have. The 'milky effect' makes the black very thin.
Did you use the Dull Black from the Admiralty paint set?
What primer if any did you use?
I am dying to have a go, the practice sprays I have done, look okay, except very washy, so may need to use less water to thin it.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#1403 Posted : 22 July 2013 23:35:39
claret wrote:
Hi Alan,
Love the modsDrool
Claret
Thanks for the encouraging comments Claret, very much appreciated...Cool Cool
Best way to learn about the consistency of the paint and how much to thin it down is simply to keep practicing and making notes of your thinning ratio until you get the desired effects.. Also, I found the best way for me was to actually do 3 or 4 very fine coats rather than try to do it all in one... The other beauty of the airbrush is with the right consistency of paint you can actually bring the grain out in the wood...Cool Cool .. I didn't use Admiralty dull black I actually used tube acrylic paint ..Galeria Mars Black, available from Hobbystore, this paint has to be thinned down...
Hope this answers your question...
Best regards
#1404 Posted : 22 July 2013 23:38:07
Tonight I finally finished the keel and to finish off the evenings work I painted black some of the bamboo strips ready for fitting the wales....Cool Cool .. Am going to darken the keel a little and am experimenting with various stains to get the effect I want... I do know I am not using walnut stain, makes it far too dark.....BigGrin BigGrin .. Issue 39 complete so no onto issue 40....Cool Cool
#1405 Posted : 22 July 2013 23:41:36
Finally, thought I would leave some pics of how she is now but the right way up....BigGrin BigGrin .. She is now sitting in the build cradle meant for the Vic, fits in there nicely... Thanks to Bernd for the tip....Cool Cool
NMBROOK
#1406 Posted : 22 July 2013 23:54:05
She looks fabulous AlanCool Cool
Before comitting to stain the keel darker I would decide on what finish you are putting on.Because of the tint in varnish it will darken the keel but not the hull because it is dark already.I had the same problem with my build,the maple was much lighter in sheet form used on the keel,but the varnish has mellowed this right down.It is certainly worth trying it on offcuts of planking and keel material.
Kind Regards Nigel
#1407 Posted : 23 July 2013 00:06:01
Kind Regards Nigel
Thanks Nigel, it is exactly that that I am doing at present on offcuts of the sheet Walnut... I don't want to darken it too much but am looking for a bit of a better match... You are correct, the sheet walnut is lighter than the strips... So far, I have found giving the sheet walnut a coat of light oak stain gives a better colour match... but will continue to see what else I can come up with.... Cool Cool .. Am also experimenting with finishing the hull off with sanding sealer (Shellac) but with a very light fine sanding to finish it off, just to take the shine off....so far I quite like the look of that finish...Cool Cool .. Have to say though I am quite enjoying experimenting with the different materials, its fun....BigGrin BigGrin
Thanks again,
#1408 Posted : 23 July 2013 00:13:28
She is really stunning mate, I aspire to your skill with wood
#1409 Posted : 23 July 2013 00:17:38
Thanks for the very positive comment Jase, its so appreciated and makes the efforts all the more worthwhile....Cool Cool .. Also have to say, I have seen your skills not only in wood but in plastic and etch too, you have nothing to aspire to as your work is superb.....Cool Cool
Thanks again.
NMBROOK
#1410 Posted : 23 July 2013 00:44:44
Kind Regards Nigel
Thanks again,
I think it is a case of finding what works best for you with what equipment you have.For me it's ronseal mattcoat.But I spray it through an automotive touch up gun using a 2.5hp compressor and I appreciate not everybody has this equipment to hand.I will say though having tried just about everything,I can't better it.
Kind Regards Nigel
#1411 Posted : 23 July 2013 00:50:06
Kind Regards Nigel
Thanks again,
Kind Regards Nigel
I agree with you Nigel, at the end of the day as long as I don't do anything to spoil the overall appearance then I think I will be able to say to myself, one nice looking build...Cool Cool .. Think that is what we all really aspire to.... Like you say, experimentation is a key factor to this hobby so the more we do the more successful we will become...
KobusBeukes
#1412 Posted : 23 July 2013 05:19:47
Hi Alan
Wow,Drool she is realy looking nice!BigGrin
Kobus
Current Build
claret
#1413 Posted : 23 July 2013 08:02:04
Hi Alan,
Thanks for the info on your airbrushing.
I will experiment some more, I think it will work okay doing a few coats.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#1414 Posted : 23 July 2013 22:30:06
KobusBeukes wrote:
Hi Alan
Thanks for dropping by and for the very nice comment Kobus....Cool Cool
#1415 Posted : 23 July 2013 22:31:43
claret wrote:
Hi Alan,
Claret
No problem Claret, if I can help in any way then you just simply need to ask..... good luck with the airbrush and get lots of practice....BigGrin BigGrin
#1416 Posted : 24 July 2013 10:08:46
Alan, she is looking fabulousBigGrin your skill factor gets better all the timeCool Kind regards Mike
#1417 Posted : 24 July 2013 22:42:13
Thanks for those very positive comments Mike, appreciate you taking the time to look in... Cool Cool Cool .. Loving this build and now have a few ideas of my own to make the build a little more personal..... Cool Cool .. All will be revealed in good time....
Best regards
#1418 Posted : 24 July 2013 22:49:22
Tonight I managed to finish the portside wales including the cutting and touching up with Admiralty dull black....Cool Cool .. Found it a fairly straight forward process even though a little time consuming... Tomorrow I will make a start on the starboard wales before tackling the two stern pieces....Cool Cool
#1419 Posted : 24 July 2013 23:10:27
Looking Cool Alan ThumpUp
#1420 Posted : 24 July 2013 23:14:37
Thanks Mr T, appreciate you looking in and for the positive comments.... BigGrin BigGrin
Best regards
Guest (13)
This page was generated in 0.579 seconds.
