162 Pages «<7172737475>»
claret
#1441 Posted : 27 July 2013 09:32:53
Hi Alan,
Nice workDrool
Good tip with the change of glue!
I think I will take up Nigel's advice and get an Amati cutter, I have a time to order.
Keep up the good work.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#1442 Posted : 27 July 2013 13:10:57
claret wrote:
Hi Alan,
Nice workDrool
Claret
Thanks Claret, appreciate the support....Cool Cool
#1443 Posted : 27 July 2013 21:34:24
Hi Alan.
Coming along really well there! That black and red shows off the hull nicely too, well done M8. Cool
Those cutters are a really worthwhile investment. I couldn't afford the Amati one and went for a cheaper version by Linic Products Ltd, you get what you pay for though, mine hasn't got such a strong handle design so it can't cut quite as thick a piece of wood but it's still very useful for all that, (remember my plastic side steps! BigGrin ). The other 'cutter' I use a lot is the old safety razor blade, the ones with one sharp edge and the other under a rolled rounded metal edge. For wood strakes up to about 1mm it does the business (also ideal for carefully trimming off the excess rigging threads!
Keep them coming Alan!
#1444 Posted : 27 July 2013 22:17:57
Plymouth57 wrote:
Hi Alan.
Hi Robin and thanks very much for the positive comments, I appreciate your continued support....Cool Cool.. Am having a look at the amati cutter and will probably put an order in for one this weekend since it comes so highly recommended.....BigGrin BigGrin .. Thanks for the tips Robin, everyone of them a welcome.... Cool Cool
#1445 Posted : 27 July 2013 22:24:02
Small update... continuing with lining the ports and have now completed the lower lining on each port on the port side, have also completed the upper lining on the lower row of ports...Cool Cool .. Am finding it easier the more I do. Also as there isn't a lot of surface for the lining to hold onto I found if the lining is a tight fit it holds nicely without any problems, too loose a fit and its likely to fall off...BigGrin BigGrin .. Obviously it shouldn't be so tight that it needs to be forced.... Cool Cool .. More of the same tomorrow...
NMBROOK
#1446 Posted : 27 July 2013 23:25:48
Coming on well AlanCool Cool
Lining the ports is one of those jobs that can make or break a model.If it's not right you're eye gets drawn to it,no matter how good the rest of the model is.You do right taking your time,slowly slowly catchy monkey is the name of the game here.BigGrin
Kind Regards Nigel
#1447 Posted : 27 July 2013 23:42:05
Agreed Nigel, gun ports are a definite focal point of any model like this and although found it fiddly to start with I think I am now getting into the swing of it..... Cool Cool .. Intend taking my time not only on this task but on the whole build, rush it and I know I will regret it for as long as I look at it....Cool Cool .. Just so you are aware, I have just now ordered the Amati master cutter with additional blades so will see how it is when it arrives.... thanks for the tip...... Cool Cool
Best regards
NMBROOK
#1448 Posted : 28 July 2013 00:02:57
Best regards
Hi Alan
You won't regret it,money well spent,great for deck planks if you rig a stop up.I am treenailing my wales on the other side this weekend and it breezes though the 0.5mm copper wire without bending the end like sidecutters tend to do.BigGrin
Kind Regards Nigel
#1449 Posted : 28 July 2013 22:57:16
Lining of the ports is progressing nicely if not slowly... Changed to using superglue gel as even serious glue was not as effective as I liked... Cool Cool .. 12 ports now complete, most of the others only have one side to fit and the top row have both sides still to do.... More tomorrow....Cool Cool
Happy building all..
NMBROOK
#1450 Posted : 28 July 2013 23:04:43
Excellent work AlanCool Cool
I'm backtracking at the moment,catching up on the other side,I have treenailed the wales.All being well I will gunport lining too by next weekendLOL LOL LOL LOL Blink Blink
Kind Regards Nigel
#1451 Posted : 28 July 2013 23:06:30
Kind Regards Nigel
Thanks Nigel, if you are doing gunport lining next week then you have my deepest sympathy.... look forward to seeing your work though...Cool Cool
Thanks again...
NMBROOK
#1452 Posted : 28 July 2013 23:11:21
Kind Regards Nigel
Thanks again...
Thank you Alan,It is probably the only job I hate with a passion,I'd rather treenail,shouldn't be that bad,as I only have the one side to do.I still reckon on 2-3full days though.
Kind Regards Nigel
#1453 Posted : 28 July 2013 23:19:11
Kind Regards Nigel
Thanks again...
Kind Regards Nigel
There is where you experience shows, I'm looking at around 2 weeks at this rate....Blushing Blushing
NMBROOK
#1454 Posted : 28 July 2013 23:29:10
Kind Regards Nigel
Thanks again...
Kind Regards Nigel
I suppose,but it was my experience that led me not to fit the decks inside.I know how hard it is to line them when you can only get to the outside.It is easier when you can get to both sides.From now on I try to do as much work on the hull before fitting decks.I am not sure how I am going to tackle Trinidad yet,but am a long way off starting her.I do appreciate though that the majority of builders will not deviate from the instructions and that is a good thing.
Kind Regards Nigel
#1455 Posted : 28 July 2013 23:38:50
NMBROOK wrote:
Kind Regards Nigel
Thanks again...
Kind Regards Nigel
Kind Regards Nigel
I think Nigel every builder has to approach these builds in their own way and it really is down to the experience of the builder... I am making changes to personalise the build but mostly cosmetic..... I too have subscribed to the Trinidad and maybe I will be a little bit more adventurous with that one but like you am a long way off from starting.....Cool Cool
NMBROOK
#1456 Posted : 28 July 2013 23:49:53
NMBROOK wrote:
Kind Regards Nigel
Thanks again...
Kind Regards Nigel
Kind Regards Nigel
I have hopefully some 'belters'in the melting pot for trinidad.Been talking to a professional model maker on msw.He is producing a shapeways program for 3d printing a super accurate stern complete with balconies.I am hoping this will be available to order through shapeways.I also have a sheet of red ochre stained boxwood veneer to cut the planking out of ,to replicate her at trafalgar.Bought it now as I will be using a little on my sovereign,but as for what,you will have to wait and seeFlapper
Kind Regards Nigel
#1457 Posted : 28 July 2013 23:57:26
NMBROOK wrote:
NMBROOK wrote:
Kind Regards Nigel
Thanks again...
Kind Regards Nigel
Kind Regards Nigel
Kind Regards Nigel
I wait with bated breath,,,Flapper Flapper .. All I know at this stage is I want to go down the natural wood look, no paint or stain....
Admiral Anti Spiral
#1458 Posted : 31 July 2013 13:55:34
lovely work alan, the work on the gun ports really brings the ship to life, looks great!Love BigGrin BigGrin
Processing - Progressing
Previous builds: HMS Victory
#1459 Posted : 31 July 2013 22:38:52
Thanks Admiral, appreciate your support and very kind comments as always.... BigGrin BigGrin
#1460 Posted : 31 July 2013 22:44:04
Well, happy to say I have finally finished the gun port lining on the port side and am fairly happy with the overall results...Cool Cool .. Can also say my Amati chopper arrived today and I used it for the very first time this evening.... can honestly say a must tool for any builder, it makes the cutting of timber and other things a real breeze...BigGrin BigGrin .. Huge thanks to Nigel for recommending I get one...Cool Cool
Tomorrow will make a start on lining the ports on the starboard side, another few evenings of work yet before I can finally leave issue 40... a tedious task but needs to be done...Mellow Mellow .. Not the best pictures, appear to be having a problem with the macro setting on the camera so will have to a look at that...Blink Blink
Happy building.
Guest (10)
This page was generated in 0.278 seconds.
