33 Pages «<1617181920>»
willz buildz Options
willz
#341 Posted : 09 August 2013 22:11:35
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
Had some 1.5 mm ply so I used this for my jig, first I super glued a 2 mm thick strip on the top edge of the jig, this strip is 2 mm thick to marry up to the 2 mm width of my gratings
willz attached the following image(s):
willz
#342 Posted : 09 August 2013 22:12:44
Next I stuck two strips of double sided tape on the jig, this will help to keep the grating strips in place.
willz
#343 Posted : 09 August 2013 22:14:08
Place the strips in the jig and then super glue another 2 mm thick strip to sandwich them in place, I ran the super glue down the back edge whilst holding the 2 mm strip tight against the grating pieces, then leave to dry for about 10 mins
willz
#344 Posted : 09 August 2013 22:16:08
Before I ran them down the saw I filed all the grating strips in the jig just to make sure they are all the same width, any rouge thick pieces sticking up will prevent the saw blade going to the correct depth
willz
#345 Posted : 09 August 2013 22:17:22
After cutting the grooves in the pieces gently remove them from the jig
willz
#346 Posted : 09 August 2013 22:19:57
All we have to do now is assemble them (sounds easy doesn't it), I assembled them dry, no glue whatsoever, gently slotting them together till the square was complete.
Next mixed pva 1 part glue to 1 part water and brushed both sides, at this point I selected the best side and with a brush with just water on brushed away all signs of glue (this will not remove the glue thats soaked into the joints it will just clean up the appearance). Then left to dry overnight
willz
#347 Posted : 09 August 2013 22:36:33
Lastly when dry I filed the gratings to make them flush, this was done after these photos were taken and the result can be seen in the the boat itself, a word of warning !!! you have to file against the top row of gratings to stop the bottom row breaking, see photo below you must file where the green arrow shows and not the red arrow, if you file in the direction of the red arrow the bottom gratings can break.
Thats about it lads and lasses, its not easy to do and I had a few failures but got there in the end.
sparks
#348 Posted : 09 August 2013 22:47:29
Lovely work Willz Love
#349 Posted : 09 August 2013 23:01:42
What a super little tutorial Willz, thanks for sharing.... Cool Cool
DaDokta
#350 Posted : 10 August 2013 11:51:37
Amazing work!!!!
Thanks for the tutorial.
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#351 Posted : 13 August 2013 21:55:16
Hi wilts.
Fantastic job on your gratings look forward to seeing more. Ian Cool Cool
willz
#352 Posted : 14 August 2013 14:56:31
Thanks for the comments lads, appreciated.
not much done, started on the thwarts and finished all double planking
#353 Posted : 14 August 2013 15:15:21
Outstanding piece of workmanship.... Drool Drool
willz
#354 Posted : 15 August 2013 19:07:22
cheers Alan, appreciated.
next, hooky thingy`s
Perksy
#355 Posted : 16 August 2013 00:06:53
Rank: Beginner Level 3
Fantastic detail Willz. Can't believe how you can make
something so small look so good. Must have a heap of Tom
Thumbs working for you. LOL
Perksy
willz
#356 Posted : 17 August 2013 20:07:05
Cheers Perksy appreciated
Now for the oars,
First I just filed one out of a piece of strip boxwood
Then this one was used as a template for all the others, below is a set of photos showing basically how I made them
willz
#357 Posted : 17 August 2013 20:11:17
I did break one or two Cursing
willz
#358 Posted : 17 August 2013 20:14:12
And lastly just a few in the barge, not sure how many to make without going overboard (sorry for the pun) I made the grapnel anchor a while back out of brass wire and plasticard.
Only the rudder left to do
#359 Posted : 17 August 2013 20:17:24
My what big hands you've got LOL LOL LOL
Stunning work I am very impressed its quite a skill you have Cool
#360 Posted : 17 August 2013 20:34:13
BigGrin loverly work there , makes me think on how you could improve on the 'HMS Endeavour's longboat Kit' not that its a bad kit as it is but you certainly have the skills to make it something special
This page was generated in 0.102 seconds.
