162 Pages «<8283848586>»
#1661 Posted : 02 September 2013 08:08:23
Blink Hi Alan sorry to hear about your probs Blink Just got back from carp fishing in France and have iooked at mine the mast hole is .5mm outCursing the hatch is spot on rgd MartynBigGrin
#1662 Posted : 02 September 2013 22:53:18
Thanks Martyn, we get these problems from time to time but the important thing is what we do to find the solutions... At least with yours a .5mm deviation will be easy to fix and won't be noticeable.... Cool Cool
Thanks again and regards
#1663 Posted : 02 September 2013 22:59:20
Well while waiting for the replacement decks to arrive I had a look to see what I would do next.. Settled on starting work on the hatch gratings and decided to make some changes here.. First thing I did was to cut away the deck support beam but left a small ear either side, filed the ears down to ensure the gratings would sit on top without ending up above deck level...Cool Cool.. This also helped to ensure the grating when being fitted wouldn't fall through the hatch hole...Cool Cool
#1664 Posted : 02 September 2013 23:03:03
Replaced the 2mm grating kit supplied with 1mm, took a total of 3 kits to complete one hatchway... Tried to ensure most of the joints would actually be on the underside and not visible... Cool Cool .. Once complete glued and fitted into place ensuring a snug fit...Cool Cool
#1665 Posted : 02 September 2013 23:10:44
Took some 1 x 3mm birchwood strips and gave them 2 coats of walnut stain, when dried cut to size to surround the gratings. Cut the corner joints at 45 degrees and test fitted, used very fine sandpaper to ensure nice joints..Cool Cool .. During the test fit thought the hatches looked large so also decided to fit a cross member again in walnut, this also hid the couple of joints in the grating strips that could be seen... Once happy everything glued in place and am really happy with the results... Cool Cool .. Will make a start on the other hatch tomorrow.... Cool Cool
Happy building all
NMBROOK
#1666 Posted : 02 September 2013 23:24:04
Lovely work AlanCool Cool Looks great,notching the central rib into the frame is a nice touchCool
Kind Regards Nigel
#1667 Posted : 02 September 2013 23:31:52
Kind Regards Nigel
Thanks Nigel, notching the central rib into the frame just looked like the right thing to do, looked odd without and it just sitting flush....Blink Blink ... Very pleased with it, all it needs now is a couple of coats of varnish.... Cool Cool
court orchard
#1668 Posted : 03 September 2013 01:47:47
Cracking work Alan, those 1mm Gratings look superb and the mod of the centre rib is a brilliant idea. Gratings were designed to be removed for access, so over large gratings would have been impractical to manhandle.BigGrin
#1669 Posted : 03 September 2013 08:00:27
BigGrin Bril work as all ways Alan BigGrin Rgd Martyn
Marcel
#1670 Posted : 03 September 2013 17:25:00
You cut the skylight frames in a modern technique of 45 degrees (picture framing). Its to be overlapping if you want the authentic look.
The gratings can be ordered from shops if you want to wait.
Marcel
Sovereign of the Seas
#1671 Posted : 03 September 2013 20:31:40
Hi Andy, thank you for the very nice comments... Agreed, the gratings did look large when scaled up so simply decided to split into two halves.. it may not be authentic but I like the look of it... Cool Cool
#1672 Posted : 03 September 2013 20:32:44
Thanks again Martyn, appreciate your nice comments... Cool Cool
#1673 Posted : 03 September 2013 20:36:31
Marcel
Hi Marcel, appreciate your comment and know you are correct with the overlapping technique.. I'm not after true authenticity with this build, if I were then I would be following Nigels build as far as I could.... Cool Cool .. Am simply going to carry on doing the gratings as I did however, in future builds and especially the Vic I will be going all out to be authentic as far as possible...Cool Cool Thanks again for looking in.... Cool Cool
#1674 Posted : 03 September 2013 20:45:54
BigGrin Hi Alan 45deg joints have been around since the 12c just look at timber framed buildings BigGrin Rgd Martyn
KobusBeukes
#1675 Posted : 03 September 2013 20:46:38
Hi Alan
As always your works looks great! Drool
Kobus
Current Build
#1676 Posted : 03 September 2013 22:21:15
Thanks Martyn, to be honest you can't see the joints with the naked eye, can only see them with optivisors on. I see it as a minor issue that doesn't detract from the build in any way.... Cool Cool ..
#1677 Posted : 03 September 2013 22:22:15
KobusBeukes wrote:
Hi Alan
Thanks as always Kobus, appreciate your support.... Cool Cool
calv
#1678 Posted : 03 September 2013 22:37:20
Been following your build with interest very impressive.
Ongoing Builds
Deag HMS Victory
Deag Soveriegn of the Sea
#1679 Posted : 04 September 2013 00:54:53
Thank you for the very kind comment Calv, do hope my diary helps you in some way on your own build..... if you have any questions then please just ask..... Cool Cool .. Thanks again for looking in....
#1680 Posted : 04 September 2013 14:29:26
Hi Alan.
Shes looking superb. keep up the good work. look forward to seeing your progress. Ian Cool Cool BigGrin
This page was generated in 0.218 seconds.
