 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
When gluing the throttle sensors to the plenum it says to use adhesive but it doesn't say whether it's plastic or instant. Which is it? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
 Hi Steve I used a medium super glue here as it is plastic to metal joint Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
The front part of the plenum which holds the pop off valve is plastic unlike the main body of the plenum which is metal and the sensors are plastic which to me suggests use plastic glue but the instructions say hold for 1 min which usually means that instant is to be used so a bit confused. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 I was working from memory on this one and yes your right about it being plastic, the reason I used super glue was because you could insert the part and dab some glue at the rear inside of the part so no spillage at the front joint. At the end of the day it is not cast in stone that you must use a certain glue unless it is specified for that part, if no glue is specified just use the one you use for general use thats what I do Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
You right Andy, and being so far into the build and getting used to what glue/adhesive to use on certain parts by now should be part of the norm and no specific type of glue is cast in stone as some people will prefer to use something different to what is suggested to what suits them. Spencer
ok, cheers Andy. I'll have a go later and see which is the best to use. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
