 recieved four bevelled planks the lengths are the same as the rest of the planks which can be secured to a maximum of 6 frames  on Tomicks build 1st folder post 23 "armour strips" Tomick says the planks run from frame 5 to frame 13 which = total of 9 framesDownload insrtructions says 1 strip runs from frame 6 to frame 12 (total of 7 frames)along the lip and another plank with the bevelled edge immediately underneath it  can someone please advise or as 'Arry Hill would say "theres only one way to find out FIGHT!!!" I think i will follow Tomicks build (he who must be obeyed) using 2 angle strips to cover 1 line of planking between frames 5 to 13 port & stbd sides
I found 5-13 was spot on and is one single line of bevelled planking, think there was a typo error.
 thanks for advice appreciate the reply
