Micro-Mesh dual angle sanding sticks Options
#1 Posted : 08 June 2016 11:52:23
These soft padded, double-sided flexi files let you sand convex or concave curves, small slots and other hard-to-sand shapes without gouging or scratching.
Each end of the file has a 15 degree taper for deburring, sanding and polishing hard-to-reach areas. Use them on wood, metal, plastic, fiberglass and most other materials. Clean with soap and water for extended life. Use dry or wet for ultra-smooth finishes.
Available here: http://www.modellingtools.co.uk/sanding-62-c.asp
For any web site order of a Paint Set from MIG Ammo, AK and Vallejo, Modeling Tools will send you a sample of the new Dual Angle Micro-Mesh sanding stick. Promotion valid between 8th to 30th June 2016 or until stocks of Micro-Mesh run out.
