Error on startup Batteries I have are https://www.ecoluxshopdi...-2600mah-button-battery
Switched the model on It jumps forward Green LED is solid Red LED is really faint Head rotates at expected pace Head roates back to the front Red LED still faint but the projector is on showing Luke on repeat but no blue LED Any ideas?
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
Can you check all the cables seated firmly in place and in the correct slots. If you have, or can get hold of a multimeter, then check the output from the battery box by holding the prongs on the positive and negative terminals, it should read 12.3v. Regards Mark Regards Markwarren (Mark) Admin
