 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,883 Points: 17,801 Location: ipswich
STAGE 1:
Hood and headlights.
Pic 1: Locate the light body 1F and the light unit 1D.
Pic 2: Fit the light unit into the back of the light body as shown. It will only fit one way.
Pic 3: Assemble the other light with parts 1E and 1G in the same way.
Pic 4: Store your parts safely for now.roymattblack attached the following image(s):
STAGE 2:
Fenders (wings) and headlights.
Pic 1: Locate the front section 2B and the 2 x sensors 2A. The sensors will fit where indicated on the inside of 2B.
Pic 2: Sensor fitted and fixed with 1 x ‘A’ screw.
Pic 3: Other sensor fitted and fixed with 1 x ‘A’ screw.
Pic 4: Locate the front section 2B and the 2 x headlight lenses 2H. The lenses will fit where indicated on the inside of 2B. Each one will only fit on one side.
Pic 5: Shows the lenses fitted.
Pic 6: Locate the lower spoiler 2F. It will fit under the nose section where indicated.
Pic 7: Fit the part in place and fix with 2 x ‘A’ screws.
Pic 8: Locate the two side panels 2G and the sidelight parts 2 x 2D and 2 x 2E. The parts have the same numbers/letters but they are all actually handed left and right.
Pic 9: Fit the light parts together as shown. They will only fit one way.
Pic 10: From the inside of the side panels, slide the light assemblies into the locating slots.
Pic 11: Store all parts safely for now.roymattblack attached the following image(s):
