 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,883 Points: 17,801 Location: ipswich
STAGE 1:
Sauron’s mask.
Pic 1: Fit the eye bases A1 and A2 inside the mask M1 as shown. They will fit over the screw posts with no pressure. They will only fit one way.
Pic 2: Fit the eye covers A4 and A5 over the eye bases. Again, they will only fit one way. Fix with 2 x MS4 screws in each.
Pic 3: Fix the nose base A3 inside the mask using 2 x MS4 screws.
Pic 4: Fit the mask upper front M3 in place on the mask base M2 as shown.
Pic 5: Fix from behind with 3 x MS4 screws.
Pic 6: Fit the mask M1 to the base M2 as shown.
Pic 7: Fix from behind with 1 x MS4 screw.
Pic 8: Store safely for now.roymattblack attached the following image(s):
STAGE 2:
Sauron’s helmet.
Pic 1: Fit the rear plate M5 to the base M4.
Pic 2: Fix from the inside with 4 x MS4 screws.
Pic 3: Locate the neck posts A7 and A8. Note they are a different profile.
Pic 4: The printed instructions do not show the parts with the correct shape.
Pic 5: Fix the neck part A7 inside the helmet as shown with 2 x MS4 screws.
Pic 6: Fix the rear neck part A8 with 2 x AS5 screws.
Pic 7: Fit the assembly to the mask from the previous stage and fix with 1 x MS4 screw where indicated.
Pic 8: Press-fit the cover A6 in place.
Pic 9: Store everything safely for now.roymattblack attached the following image(s):
