 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,883 Points: 17,801 Location: ipswich
STAGE 1:
Front face.
Pic 1: Fit the trim piece 1E to the bumper 1A as shown and fix from behind with 1 x PS21 screw.
Pic 2: Repeat at the other side with trim piece 1F.
Pic 3: Fit the centre trim 1D in place as shown. There is a raised dot on the rear of the trim where indicated in yellow. The trim fits this way round.
Pic 4: Fix from behind with 4 x PS21 screws.
Pic 5: From the inside, fit the indicator lenses 1K and 1L.
Pic 6: Fix the indicator housings 1G and 1H where shown using 2 x DS01 screws in each.
Pic 7: Assemble the light units 1J and 1N and 1M and 1I as shown. The parts will only fit one way.
Pic 8: Fix the assemblies inside the bumper where indicated using 2 x DS01 screws in each.
Pic 9: Press-fit the red trim 1D to the grille 1B as shown. Note the highlighted curved section which must be at the top.
Pic 10: Fix the grille to the bumper using 3 x DS02 screws from behind.
Pic 11: Press-fit the M3 badge in place as shown.
Pic 12: Store safely for now.roymattblack attached the following image(s):
STAGE 2:
First wheel.
Pic 1: Peel the backing from the badge 2J and fix it to the centre of the cap 2H. NOTE – You may find the badge is already stuck in place.
Pic 2: Press-fit the valve 2I into the locating hole in the rim 2D.
Pic 3: Flex the tyre 2A and fit the 2 x inserts 2E as shown.
Pic 4: Press the 2 x joining clips 2F into place as indicated.
Pic 5: Fit the rim parts 2C and 2D together making sure the locating points on both parts line up.
Pic 6: Fix from the other side with 2 x DS08 screws.
Pic 7: Fit the mounting bolt ring 2G in place as shown.
Pic 8: Fit the assembly into one side of the tyre 2A.
Pic 9: Fit the inner rim 2D in place making sure the locating pins highlighted in blue are in line with the matching holes. Fix the rim parts together with 4 x DS08 screws.
Pic 10: You can add the centre cap here but it will not yet stay in place so store it safely with the wheel.roymattblack attached the following image(s):
